Results 1 to 10 of 10
    Mar 2010
    Indianapolis, IN
    Question Which LED headlight is better?
    I am considering updating the headlights on my F3L to LED's from stock. I see that some of the conversions have cooling fans and others(specifically Lamonts) say that due to the design no fan is required. I know of one person I ride with occasionally had a fan fail and had to replace it when it started making a screeching noise. Would appreciate feedback from anyone who has either style with good or bad thoughts about with or without the fan.
    Active Member Spyder601's Avatar
    Jun 2012
    Brandon, MS
    Quote Originally Posted by funon3 View Post
    I had the Bulbs from Lamont in my ST and they were great.
    I'm of the opinion that the less moving parts the better.
    17 F3 Limited (Pearl White), Sena 10C intercom, X Grip iPhone mount, IPS key, spyder to go cup holder, Lamonster Highway Center Lane, TricLED engine lights, TricLED night rider, LS2 Helmets, Lamonster Bypass pipe, 2 Brothers Exhaust, mirror relocator kit, Bluetooth radio module, OEM Backrest, Rear LED Light Kit
    2017 F3-T , Pearl White
    Aug 2015
    Canton, Ohio
    I got mine from TricLED and it was a snap, no pun intended.
    I did not have to do any trimming, cutting or anything at all, it was a breeze. I had them for about a year now and they have been a blessing.
    Joe
    Greenville Tx
    I also had the Lamonster Headlight replacement on my ST LTD. They worked great and I plan to get them put on my F3L also, especially now that I have the Fog lights and they are a different color.
    2017 F3 Limited
    Danbury Connecticut
    I have Lamonts LED headlights and foglights.
    I'm very happy with them. I can only imagine the F3 lights are equally as good.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Oct 2015
    Lynden, WA
    Default LED Headlights
    I have the Bulbs from Lamont in my 2013 ST and they work great.
    I agree the less moving parts the better.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Mar 2010
    Indianapolis, IN
    Thumbs up Lack of fan not a problem.
    Quote Originally Posted by Haze View Post
    I already have Lamont's fog lights installed and the lack of fan cooling on his bulbs doesn't seem to be a problem. Thanks for all your input. I'm leaning toward Lamont's headlight bulbs.
    Dec 2016
    Florida
    I also have Lamonster's in my 17 F3 Ltd. No issues.
    Oct 2011
    Jacksonville,Ar
    I have both led fog and headlight for over a year from lamont.
    15 rt , yes Black
    May 2016
    Central Florida
    +1 for TricLED. I can't say the install was easy, but I did get it done. Of course, the install has zero to do with the quality of the LED's. That's an accessibility issue depending on your model design.
