I gotta ask, what does the manual say on Page 33 about that section of the dash?
Do you mean this view?
Maybe the 70 you're seeing is Trip Distance or Max speed? If it's fuel consumption, I'm ordering an '18 today!
The Statistics menu is used to get :– Trip distance information
– Trip elapsed time information
– Instant fuel consumption
– Average fuel consumption
– Maximum speed
– Average speed
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
Goebel
Maybe the 70 you're seeing is Max speed?
– Maximum speed
– Average speed
The manual tells nothing . One of the worst manuals I've seen . They don't even know at my Can Am store . meerkat
Reason: more info
Yea, I just read it, and I've watched several of the BRP Tutorial Video's and they gloss right over it. Even the example in one of their video's has the Inst 70 and Avg 70 bars which would appear to be the same as what you stated. Maybe the gauge isn't updating (that statistic) and is stuck on the "DEMO" mode or something?
Watched this Youtube vid 2018 Can-Am Spyder Gauge User Experience and the Youtube vid 2018 Can-Am Spyder Gauge Overview
Both flash right by the screenshot above.
Safe Rides,
IBA 70020 |
It says MPG but he only has 1.2 miles on it
According to mine I have
713.4 miles on it and it took 27 hours and 18 minutes.
my max MPG is 91 (probably idle)
and my average is 26
my phone battery is fully charged and my Bluetooth is 1 bar.
I will post a pix later
Nope the 15 is Max speed on that trip.(That's a screen grab I got from one of the BRP videos), and The OP said his has been on 70 everytime he checks it.
Safe Rides,
IBA 70020 |
70 is not max speed. I had it much faster than that and mine shows 70 also
Try "clearing" that 70, and see what happens.
(It may have been left in there from a calibration attempt... )
Checked the new ones at the store , they say the same thing .
Mine has 70 also. I cleared both A & B trips as all data in the 3rd tab that shows the odometer.
TGHe one thing I'm still waiting for is the software update. I have Tri Axis bars, Backrest and different wheels to be installed and the dealer has been too busy to install them and they want to be able to do the software update at the same time and now that their service tech has had an accident I have to wait another 3 weeks.
Anyone had the software updated yet? If so, how?
– Maximum speed
– Average speed
Yes , that's the one and the top white horizontal bar says instant MPG and starts when you start moving and looks to be correct . The bottom yellow bar says average but never moves . I'm sure its suppose to give you your average MPG . but don't . meerkat
Meerkat, It looks like you're the first to find that issue, have you passed this along to BRP Cares since your dealer doesn't know? Maybe with the help of a passenger or a chest mounted Go pro type video camera you could film that display section not updating while riding. Safety first though eh?
Safe Rides,
IBA 70020 |
DGoebel
No , I didn't know about "BRP Cares" , I'll try to find them . I did call Can am and they told me to call the dealer , but they say they don't know . Oh well , I guess it will come out eventually . Thanks , meerkat
E-mail sent , 10:30 There really is nothing to film , because it does nothing .
Reason: more info
You (we) are all too old to understand what is obvious to ANY 14 year old. You need an interpreter. Time to introduce the new Spyder to the grandkids.....They can explain it
Semper Fi
2018 RT
Originally Posted by PMK
Ironically, Can Am displays on previous years could not keep accurate time with the digital clock, what are the odds a full digital display will work correctly?
Sorry, I had to, like fishing in a fish bowl...
Yes , I guess $30,000.00 for a motorcycle is not enough to ask that it should work correctly .
2018 RTL dash
I take it you've also been in contact with Bob Denman here on SL's, he's been experiencing his new '18 dash and maybe, if his behaves different than yours, you guys can figure out which firmware version your respective bikes have. I know some software / firmware update has come out for them and can't remember if you mentioned your spyder got that update or not.
Safe Rides,
IBA 70020 |
Just to add to this thread and to verify that it's not an isolated issue, I'm having similar problems with the stats page (70 is the maximum, average MPG never changes from 70, etc). The display show the following for versions:
BRP Version: 710005255
CSS Version: 010.05
Other problems also, so if this is the "Display issues", I'll add them in a bit.
2018 Spyder RTL
My machine has not had the update as yet . Possibly that is what we need . From what I'm hearing everyone is having the same problem .
CSS Version: 010.05
2018 Spyder RTL
Macbates, Does that number even change while moving?
Safe Rides,
IBA 70020 |
Bob , Tried that , didn't help . Are you having the same problem ?
Just got back from a fairly long ride with the following results:
Trip hour meter was correct: 4 hr 32 min, which I assume is 'engine on' time. Total of 182 miles.
The maximum MPH showed 76, which is correct. Average MPH showed 40, which seems to be right for 4.5 hours and 182 miles.
Instantaneous MPG fluctuated between 0.4 (stopped) and 70 (which appears to be the maximum). It's hard to tell, but the way the instantaneous MPG varied as I up and down shifted, it seemed to be correct. Average MPG stayed locked at 70, so it's a definite bug in the software. I'll report this to BRP, but if others report this also it may help.
I filled up the tank at the end of the ride, and the actual MPG came out to 42.8, which I don't think is bad at all, especially since the bike is brand new, I had a passenger, and a lot of the riding was in 5th gear (I was in the mountains).
- Ken
2018 RTL dash
- Ken
I called BRP yesterday , they checked and had nothing on record about this problem . They told me to go to the dealer and tell them to open a case with a PRP technician , which I did today , and they told me that they did that. When I told him that they had nothing on record , he said that BRP saves those for about a week , then discards them . My machine has the initial update with the additional required cord but this does not solve the problem according to the dealer .HE said I have to wait for the next update witch is coming , no not when , and that should solve the problem . meerkat
I'm glad you are reporting all of this. At least people can be aware. Thanks.
