SE 5 HANDLE BAR SHIFTER CONTROL
I HAVE 13 RT SE5, THE SHIFTER PADDLE SWITCH HAS PLAY AND SOME TIMES NEED TO PUSH IT REPEATEDLY TO GET IN TO GEAR.IS THIS SERVICABLE OR DO YOU REPLACE THE WHOLE THING. THANKS
No
It comes with the whole command unit. Not to say you can't take a look I have fix those command (not paddle shifters never looked into them) but you have to make your own parts. make sure it is not a shift linkage or oil level problem...
Mine started to hang up a bit so I took it apart and applied some grease here and there. It's easy to get apart and take a look-see. Mine works fine now.
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
Good to know, mine has started to hang up a little bit.
