Results 1 to 25 of 26
    Dec 2014
    Graham Tx
    Default Draining the oil
    What size star torque allen does it take to remove the oil drain plugs on a 2017 F3L?
    Thanks in advance!
    Dray
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    Torx T-45 for the engine plug (the plug with the 2 o-rings). The transmission is a 5 or 6 mm allen.
    NorCal - Northbay
    and a 6mm hex bit for the trans if you have an SE6....
    Chuck
    Dec 2014
    Graham Tx
    Thanks very much. Exactly what I needed to know.
    Dray
    Houston
    Quote Originally Posted by hypurone View Post
    The SM6 is the same. Both trans have a drain under the clutch housing.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jul 2017
    sarasota, fl
    does the SM6 have a filter for the trans?
    Houston
    Quote Originally Posted by ofdave View Post
    No, only the SE has the trans filter.
    Springfield, MO
    Active Member EricP's Avatar
    Dec 2017
    Atlanta, GA
    Question Topside Fluid Extraction?
    Any benefit here to using a topside fluid extractor instead of draining?
    There is on my older BMWs as I can change oil and oil filter w/o ever getting under the vehicles / low to the ground, but not sure if I should even worry about trying to use it on my Spyder....
    2015 F3 , Stock I use the Extended Brake Pedal Silver with black stripes and Can-Am Red/Orange accents
    Quote Originally Posted by EricP View Post
    Forget it on your Spyder! Pull the plugs and let it all drain out.
    Dec 2017
    Atlanta, GA
    Cool - will do.
    Just curious why.....
    ..from Lamont's video, I can see that the filter is accessible from top-side, but there's 2 drain plugs - maybe the dipstick tube doesn't reach the very bottom so it would be too hard to get all the oil out (that your thinking)?
    Just curious why from your perspective.
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Have tried the Pella Extractor on the 1330 engine - I only get 3.5 Qts out
    I have an extractor that works well on lots of small engines to provide seasonal service. On some of those there is not a bottom sump plug so getting the oil out is a chore.
    The 1330 engine has multiple scavenge pumps and apparently sumps as the most I have removed is 3.5 qts out of the 5 Qt oil change capacity by using the filler tube entry. The extractor does assist by reducing the drain volume and can be used to suck out other reservoirs.
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Dec 2017
    Atlanta, GA
    Thumbs up
    Quote Originally Posted by AeroPilot View Post
    Awesome. Thanks for that detailed opinion AeroPilot. That helps me understand better.
    Dec 2012
    Murphy, NC
    Default GOLD PLUGS
    Dray and EricP do yourselves a favor and purchase Gold plugs. These are oil plugs that use a socket head rather than a torx or allen head. Much easier to unscrew with out worrying about stripping it.
    goldplug.com
    2020 F3 Ltd
    Spyderpops Bumpskid
    Cool - will do...Just curious why from your perspective.
    Aeropilot explained about the scavenge pumps. What these pumps do, among other things, is get all the oil in the engine to where it's supposed to be in order to accurately measure the level in the engine once it is turned off. The dipstick, as well as that suction tube from an external extractor go into the engine oil tank. About two minutes after an engine at normal operating temperature is turned off, oil from the oil tank begins to run back into the dry sump of the engine. Since you can't maneuver the suction tube from the external extractor into the dry sump, you leave oil in the engine. There's no sense in letting that old worn oil contaminate a fresh batch of lubricant. Additionally, the OEM transmission, a.k.a. clutch cover plug, has a magnet on it, as do Gold Plug and Dimple Plug engine drain plugs. Even though those magnets are generally quite clean on oil changes after the first oil change at 3,000 miles, it's very wise to inspect both (if you've installed such plugs) just to be certain you don't find any signs that something may be going awry in your very expensive engine.
    Dec 2014
    Graham Tx
    Dimple plugs are on order!!
    Dray
    Sep 2016
    dilworth,minnesota
    Default a some what related question
    Is there an EZ drain for the spyder and has any one used it
    If the EZ drain is one of those valve things there was small discussion about it quite awhile ago and some folks objected to the fact that it extends below the frame where striking a road object could possible do some severe damage to the engine casing. I'm satisfied with my Dimple plugs.
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Quote Originally Posted by JKMSPYDER View Post
    goldplug.com
    this is exactly what I did and I’m glad I did it. It will be much simlier next time (15mm & 17mm).
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Houston
    We will not install the Dimple or Gold plugs in the engine side. The one with 2 o-rings. Both manufactures install a magnet inside the plug, the bore for the magnet is too close to the o-ring groove and the plug easily shears off with little torque. If they made one without the magnet ie solid and a hex head it would help but as is, there have been too many failures. When a customer comes to us with one in the bike, IF it comes out in one piece we hand it to the customer and install a new oem plug. Will not put them in for liability reasons.
    Suggest avoiding the magnetic plugs on the engine side. The clutch side already has a magnetic plug from the factory.
    If you use the correct tools to remove the plugs, there is no problem at all with the factory plugs.
    Dec 2012
    Murphy, NC
    Default PLUGS
    I have heard of several Dimple plugs breaking at the O ring indentation, but no Gold Plugs to my knowledge. In following other threads about this, the consensus is that the Gold Plugs are thicker where the O rings go. I have the Gold Plugs and have never had an issue. Just my 2 cents.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Houston
    The basic design with the magnet hole behind the o-ring is the same. This plug has the threads on the far end of the plug so all torque must pass through this thin wall section. Bad design. Eliminate the extrainous hole for the not needed magnet and I will use them. Until then I have no reason to risk liability for a several thousand dollar repair in removing a sheared plug for risking the installation of a known inferior part.
    We will stick with OEM only on the engine side for now. And yes, I have seen a Gold Plug shear there. Its stronger than dimple but still has the problem.
    Active Member malibu_dan's Avatar
    Oct 2011
    Hotlanta
    I appreciate the real-world experience, jc. So, where is the failure point on this design? I would think the weak point in this would be where the o-ring groove is right below the threads--but this would be the same on the OEM as well.
    Houston
    The weak point is right where you think it is, at the o-ring groove. The reason the Dimple and Gold plugs are worse than OEM is the end of the plug is drilled to insert a magnet. The drilled hole is behind that o-ring groove. Thus the thin wall section the torque must pass through and were the plug shears off inside the engine. Its a major tear down to get the threaded remains of that plug out.
    Just FYI, your picture did not post correctly. Cannot see it.
    Dec 2015
    Oakley Utah
    Default Drain plugs - which is which and what torque on each?
    Drain plug o-rings.jpg oil filter housing cap.jpg engine sump drain plug.jpg Spyder oil change.jpg
    Looking at the diagram in the shop manual, it seems to have the location of the two plugs backwards.
    On my 2014RT, the non-magnetic oil sump plug with two O-rings and a crush washer, using a T-45 wrench, is on the left side of the frame, not the right.
    The smaller magnetic clutch cover plug with just the crush washer (no O-rings), using a 6mm hex wrench, is on the right side of the frame, not the left.
    When I removed the clutch cover drain plug, it took a lot of force to break it loose. But the torque spec for reinserting it is only 15 ft-lbs. Doesn't seem like enough torque to seat the washer properly.
    So, before I refill with the new oil and bring the bike back down off the jacks, can someone confirm for me that 15 ft-lbs for the clutch housing plug and 21 ft-lbs for the engine sump plug are correct?
    Thanks.
    2014 RTL Platinum
