Results 1 to 10 of 10
Thread: Trailer harness
    Jul 2013
    Vestaburg Michigan
    Question Trailer harness
    There was a sponsor that sales wire harness for trailer, RT . Can’t find him now? Can someone tell me which sponsor sold this?
    Bryant, Arkansas
    Here is the link
    http://bigbikeparts.com/link.aspx?Pr...1&GroupGuid=16
    Or call Spyderpops at 501 760-1234
    Cruzr Joe
    Feb 2012
    Spring City,Utah
    Pierre at Can Am Spyder Accessories makes a good plug and play harness. I use his harness,tho I did modify it to five wire as my trailer is a five wire.
    http://www.canamspyderaccessories.com/
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Aug 2015
    Canton, Ohio
    I used Pierre at www.canamspyderaccessories.com for mine.
    With his plug and play harness and the awesome step by step video, it worked out perfectly for me.
    Joe
    Jan 2015
    southern WI
    Quote Originally Posted by Buckeye Bleau View Post
    Joe
    Ditto..
    2016 RTS , Pearl White
    Jun 2015
    Hampton Roads, VA
    Joe
    Jul 2011
    Mitchell, Ontario, Canada
    The problem with Can Am Spyder accessories trailer harness is the module he is using. It is unpowered and does not isolate the trailer from the Spyder. So depending on the trailer and the lights it has. You may get hyper flash of the signal or hazard lights when the trailer is connected. This has been report on a couple of threads. If you get a short circuit in one of the trailer circuits. The lights on the same circuit on the Spyder will fail with an orange screen and failures messages. For a couple dollars more he could have used the correct isolation converter and these potential problems will be avoided. No hyper flash. Any shorts in the trailer and the the trailer lights will fail. But the Spyder lights will not be affected.
    Jun 2015
    Hampton Roads, VA
    Default Good point
    I went back and found I ordered from SHOWCHROME (off EBAY). Came with a relay board, and a heavy wire to run up to battery. I can hear the relays clicking when signals are on. I have read MANY forums where using the existing wiring caused failures of the module (due to grounding I think over time).
    Active Member Texas Al's Avatar
    Jun 2017
    Azle TX
    Default 2017 F3 s trailer harness
    does anyone make a plug and play for a 2017 F3 s ?
    2021 900 Ace , Black & Gold
    Aug 2017
    arkansas
    Default harness
    Quote Originally Posted by Texas Al View Post
    I used electrical connection out of Tennessee for my 17 F-3T Limited
