Page 1 of 5 12345 LastLast
Results 1 to 25 of 121
    Mar 2014
    Midlothian, Texas
    Default OEM tires improved?
    After the original rear tire on my RT only lasted 6k miles, I started using car tires. It's a pain because many dealers will not install car tires, and I don't want to worry with taking the wheel off myself. Have the OEM tires improved to the point we can consider them again, or do dealers offer a better alternative?
    INDIANA, USA
    Default OEM Tires
    SORRY, NO change. Kenda LOVES to make $$$. The CAR Tire is the better way to RYDE .
    Any tire manufactured after 2814 (28th week of 2014, at the end of the DOT string of numbers on the tire) is a harder compound than ones made before that date. The harder compound MAY give you longer life depending on how you ride. My first two tires, the soft compound lasted only around 7K while my first tire with the harder compound gave me over 11K. My second harder compound tire is approaching paws up at only 8.6K but that tire has 5,500+ miles of interstate travel at high speed. I'm just about finished researching a dealer not too far away that will install a car tire for me.
    Default They did....
    Not many gave them a second chance but they did change the compound back to the original. They do last longer now but it still depends on where, when, what and how you ryde. I got on average 16,000 miles on the Kendas and am currently on a Arachnid which I will not know for some time. Have about 7,000 on it now and it looks like I am about half or less to the wear limit. Being a mechanical machine there will be no studies as to the effects of using the car tires and the issues the spyders are having but I will continue on the recommended tires.
    The OEM tires are overpriced and of low (IMO) quality control. However, if you get a good set they are fine (once you get past the price and the low longevity). But if you get a bad one, it can be a real pain.
    Interestingly, of all the posts I've seen about bad tires over the years. I've yet to see one about a bad car tire. Maybe I missed them.
    I have seen a few posts where the OP was not thrilled with traction. Especially in wet (that's where you need to do your research). But nothing about the major build issues encountered with way too many Kenda's.
    Get the right tire to the right installer and you'll get a far superior product for less money.
    Invalid Emails
    Apr 2017
    AZ
    What's the problem with installation: Dealers that won't install other than OEM or can't find tire shop to do it?
    Default NEW TYPE KENDA
    with Ron ..... and would add that I believe Kenda changed the rubber compound ....But NOT the way they are constructed ... They are still made with less than Half the Plies that car tire are made with ....... Ask your self this .... Would you rather have a tire that is at or near it's maximum weight load (ie the Kenda's ) .....or a tire ( ie car type ) that can hold three times the weight load exerted by your Spyder ........ Another way of looking at is an " S " rated tire vs. " V " rated one, me I'd rather you the tire that was tested at 160+MPH vs 108mph ......... Mike
    I always felt that the Kendas handled okay, road quietly, and gave a decently smooth ride...
    But when you figure in the cost, and short tread-life: there ARE better alternatives out there...
    Oct 2017
    Las Vegas, Nevada
    What you're saying makes sense, but I wonder if the Kendas were designed that way in order to improve the ride (and of course to save money!). Extra plies and extra weight capacity should make the sidewall flex less, especially on a vehicle as light as the Spyder. Less flex would lead to better handling and at least theoretically, a harsher ride. I know that switching from all-season tires to ultra-performance summer tires on a car has that effect. The rear wheel of the Spyder is right under the passenger, so maybe they deemed the ride quality to be most important. That might have been BRP's purpose in specifying these tires.
    2017 RTS , Blue
    Jun 2010
    Las Vegas
    Quote Originally Posted by johnsimion View Post
    I was told by a very credible source that Kenda was THE ONLY MANUFACTURER to bid on the Spyder tires.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    They got your questions answered. The early 2014 came with "softer" rubber compound. My first tire lasted 8,900 miles. The next is 15K and still going. Most of the rear tires I have had got 15K or better.
    Most dealers that balk at installing non-OEM tires claim safety issues. I do not believe there are any safety issues with using car tires if you desire.
    My problem, I don't want any non-spyder mechanic screwing up the bike with tire removal and re-installation.
    Aug 2013
    Northern California
    I think they have improved, not saying they are worth the price, but I got 19000 on my original Kenda on the F3L. The dealer put a Kumho on as the replacement, so I will have to compare over time.
    Aug 2012
    CO
    Default Catch 22
    For me, none of my local motorcycle dealers (BRP shops) will mount car tires, and none of the auto places (discount tire, big-O) want to work on the rear Spyder wheel. I don't have the tools/desire to pull the rear tire myself. So.. any of you run Kenda (or BRP approved) tires in the back and car tires in front?
    Also, going from a 2ply to a 4ply, do you run lower pressures to reduce the harshness?
    JLohPhotos
    2008 GS , Millennium Yellow
    Default NON-MATCHING TIRES
    Quote Originally Posted by asp125 View Post
    There are ...ZERO .. issues as far as a Kenda rear and car tire fronts other than the Kenda is the weaker tire ....your Spyder will handle OK ..... and I have recommended lower tire pressures if you run Car tires either front, rear or both ends ..... a four ply tire doesn't need a lot of Air pressure to support it ........... I accidently let my Michelin Hydro-edge rear tire get down to 6 psi ...... and the Rim still wasn't hitting the ground ........ Mike
    Default Tires
    Peter Aawen and I have been recommending tires pressures for the rear ( when using a car tire ) to be 17-18 psi max..... whether one or two up riding .........The fact is the Kenda tire would be DANGEROUS at that psi, the sidewalls are thin and weak compared to an auto tire..... But with 18 psi in an auto tire you will still get a nice ride but much safer .......... Mike
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    Ask your dealer if he'll install a non-OEM tire, if you're willing to sign a waiver, and if you supply the tire. Some do.
    I wish BRP would institute a blanket policy that allows dealers to do this. The crappy Kendas are the biggest source of heartburn among Spyder riders.
    Active Member Hey Yu's Avatar
    Mar 2016
    Australia
    Better alternatives are not alternatives when the dealer is the only outfit willing to do the install.
    Mar 2016
    Australia
    Quote Originally Posted by Fat Baxter View Post
    Why would BRP want to do that?
    INDIANA, USA
    Default Car Tire Install
    Just wondering how many Bike Dealers are willing to DO the install. If you had a dealer install your tires Please GIVE a Big Shout OUT.
    Quote Originally Posted by Hey Yu View Post
    You either need better powers of persuasion... or a new dealer.
    Mine will install what I bring to him: not all dealers will.
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    I would sell my F3L before putting Kendas back on. The originals were out of round and a back replacement Kenda from my dealer vibrated from when it was new and balanced. I had to add ride-on to ride on it.
    2016 F3L , Big Bike Parts Black
    Dec 2012
    Murphy, NC
    Default KENDA REAR TIRE
    When I was in Quebec last year for the Spyder 10th anniversary celebration I asked a BRP rep if they had any objection to dealers installing car tires. He said there was no such directive. I have had a car tire installed at a dealer in East Tennessee and at a dealer in north Georgia. The rear Kenda on my ‘13 ST-S lasted less than 10,000 miles. I then had a Kumho installed and it lasted 15,000 miles. The rear Kenda on my current ‘15 F3–S lasted 11,000 miles. I then had the dealer install a Michelin Hydroedge. WOW! 13,000 miles so far and only half worn. I expect to get another 10,000 to 12,000 out of it. Too bad the Hydroedge is no longer available.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Dec 2016
    Somewhere USA
    Default yet another tire fight
    My front KENDA tires are 20,000 miles and still going strong without ANY issues.
    My rear KENDA tire was replaced at 13,000 miles but could have EASILY gotten 15,000 out of it.
    If it "aint" broke don't fix it.
    Go ahead and put a harder rubber compound tire on your ride.
    Go ahead and complete your genius by making sure it support 4x the bikes weight.
    Go ahead and emergency brake as you slide into that jackknifing trailer.
    Go ahead and later comment........Road-Kill was right.
    Oct 2017
    Central NJ
    Quote Originally Posted by Little Blue View Post
    Since I've only just purchased my 2016 ST-S, I haven't had to experience this YET, but my dealer told me that they have and would install a car tire.
    Quote Originally Posted by Road-Kill View Post
    How about if YOU try listening to some of us, who have actually logged a fair amount of miles on Kendas, and on aftermarket tires?
    Use what you want: they're ALL better than having the bike sit there on the rims...
