Results 1 to 25 of 36
    PhotoShop Master
    Jun 2008
    methuen ma/salem nh
    Default BACK UP BRAKE SQUEAK SOLVED .....
    this morning backing out of garage i heard that bad brake squeak that we have learned to grow and love
    I took a shot that pads were not seperating so i installed two small springs between brake pads on the caliper slide bolts .... so far no squeak and brakes are still functioning perfect ...i'll let you all know how it works out over time .
    Jun 2008
    Kitimat, B.C.
    Quote Originally Posted by tatt2r View Post
    Can I get a second moton for "genius"
    Invalid Emails
    May 2009
    OH/TX
    What brilliance of mind.can the spring get in a position to keep the brake from working?If not you need a patent lawyer.
    Apr 2009
    Lansing, MI
    You should sell your Brake Anti-Squeak kit on e-bay for $19.99 !!!
    Springfield, MO
    Jan 2008
    McHenry,IL.
    Brillant! Brillant
    Dec 2008
    Jacumba, CA
    A good conversation it was over coffee. I will try it next.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    PhotoShop Master
    Jun 2008
    methuen ma/salem nh
    Quote Originally Posted by wolfshead1 View Post
    Put some miles on spyder today so far working like a charm been coasting backwards with engine off and I get no squeak and I see no way that the spring will interfere with the brakes at all did a lot of stop and go driving today so far works great I got an asortment pack of springs at home depot for like 6.00 and found two that fit perfect around caliper bolt and they were not too strong to keep pads from working hope my little fix helps all
    Apr 2008
    CT. U.S.A.
    Cool
    In no way is the CHAD just a FAD
    Apr 2008
    Alabama
    Send the picture to BRP
    Sep 2008
    TX
    Another gem!
    Wayne
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Invalid Emails
    Lake Mary, FL
    Default Brake squeek fix
    Was it only your back brake that squealed? Or did you do the spring install on all wheels?
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Have you ridden with this in heavy rain yet? I am curious as to how it might affect the initial stopping in wet weather. One of the advantages of disk brakes is that they ride on the rotor, so are not easily contaminated or rendered less effective by moisture and crud (i.e., they wipe themselves clean constantly). This may still be close enough to do the job, but it does create a question in my mind. I still may try it for myself. Far less effort than completely removing the brake pads to apply Disk Brake Quiet.
    Apr 2009
    Schertz, TX
    Here is what I do not understand.....Dealer says the squeal is because of high metal content in the pads that is need to stop the spyder due to its weight. A Goldwing weighs in at over 800 pounds and their brakes do not make a sound.....
    PhotoShop Master
    Jun 2008
    methuen ma/salem nh
    thanks for input scotty ...yes i have driven in rain and stopping power is great still the spring is very light tension and pads are still touching rotor
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Thanks. After I recover enough from next week's surgery to crawl around on the floor again. I may try this. Heck, if it is boring and cold this weekend, I may even get to it sooner.
    PhotoShop Master
    Jun 2008
    methuen ma/salem nh
    I am humbled by your trying something i came up with .....
    all knowing master of cycles...
    Jul 2009
    Jacumba, CA
    How will we recognize it's a without the squeal ? we hope to do this too. Loved your runon commentary; sounds like something I would do.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    I did it this afternoon, oh wise one. No more school bus sound pushing it out of the garage or in reverse! It was a bit of a shock to have it push so easily, and to roll backward on a slight incline when stopped. I used a couple of 1/2"x1/2"x0.041" springs, stretched slightly since I couldn't find any just a bit longer. I had some thinner gauge springs the right diameter, but they were too long, and were too close to binding if the pads wore out for my comfort. I suppose I could have cut them down, but I preferred the finished ends on the whole springs.
    On the minus side, the brake pedal is a little farther down than before, at full engagement. Makes it feel a tiny bit soft, since it is just the back. One additional pump and it is rock solid. Stops just fine, but I think my spring is a little bit strong, and is pushing the piston back a wee bit. 0.020-0.030" wire would have been better, but doesn't appear to be available. A 5/8"x9/16"x0.035" spring is available on the Web, and that might be just the ticket. That one is also available in stainless. I will revisit this fix after my surgery, when I have some slightly softer springs. Meanwhile, it takes the cake! Have yet to test wet weather performance.
    I also applied CRC Disk Brake Quiet gel to the rear, cleaned the brake parts and pads, and lubed the appropiate places sparingly with CRC Disk Brake Caliper Grease. Still a tiny bit of typical squeak, possibly from the fronts. No worse than my BMW, not a squeal, just a tiny squeak if the brakes are applied lightly. So quiet I can actually hear the ventilation holes as they approach the pads now. Thanks for giving me the incentive.
    Mod Maniac
    May 2008
    North Texas
    ... I will revisit this fix after my surgery, when I have some slightly softer springs...
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by ataDude View Post
    Guess I could have phrased that one a little better.
    I will buy some new springs while I am recovering from my knee surgery, and install them when I can get down that low once again.
    How's that? Then again, having the doc install new springs in me could be helpful...
    Mod Maniac
    May 2008
    North Texas
    Whew, Scotty, I was concerned. Those springectomies are really tough... I had heard it's best to have those while you're still <<ummm>> a spring chicken.
    Good luck on the surgery!
    Aug 2008
    SLOVENIJA
    this will be next BRP recall....
    Jul 2009
    Los Angeles, CA
    Default wd40 is magic
    this is genius. But I havent had any problems ever since I sprayed WD40. works great no complaints..
    Jun 2009
    Killeen/Fort hood, Texas
    Default Rear Brake Spring
    Every time I parked my in my garage, the next day I would push out before starting and the rear brake would just howl like crazy, I would mess around with the rear brake by hand and some times it appeared to seperate the pads just enough to stop the howling, but would go right back to howling. I went to Home depot and purchased a $3.50 pack of springs, found two that were about the right size, would have to squeeze just alittle to get them in, but went in fine, not to stiff, and not to weak. After the install, like the other fellow showed in his pic, it worked instanley, and been riding for a week with lots of miles and no more rear brake noise, riding or pushing. another in expensive mod (like the truck spring and push button trunk light) that someone came up with that really works, and was nice enough to share it with all of us. Mod dose not effect the rear braking power in any way. My front brakes squeal from time to time. might try that mod on them too??........anyway thanks.
