Results 1 to 15 of 15
    Oct 2017
    Pennsylvania
    Question Why F3 rear axle nut not secured?
    After looking at other Spyder models and seeing how the rear axle nut is secured with a safety pin and a plastic cover I got concerned, because the right rear axle nut on my F3 is not secured with anything. There aren't even plastic covers. I don't care about the covers (other than they keep dirt away from the axle), but I wonder if it's just me or is it common on all F3s?
    I'm attaching two pictures - the left and right sides. The left side nut is secured with the axle flange, so it's not going anywhere, but the right side concerns me. Should it?
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Yours is correct. That's the way they are. 23,000 miles on my first F3 with no issues.
    2020 RT Limited
    2020 RT Limited , Petrol Blue
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by Don'tPanic View Post
    I agree with you, the axles should have a cotter pin. It's standard safety practice.
    Darrell
    United States
    18k on my F3S and no problems. Wheel has been off for a tire change also.
    May 2009
    Connecticut
    I noticed that also BUT when you Put 100Pds of torque to tighten it I don't think its going anywhere Fast?
    Sea Doo GTI-SE 90 Jet Ski!!
    Harrington, Australia
    Quote Originally Posted by Sarge707 View Post
    Actually 160lbs on the 2013+ Sarge
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2017
    "Granite State"
    Default Quick Fix:
    If concerned, why not just ad another axle nut & thin spring washer? They're thin & it looks like there's enough thread/space.
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by Roadster Renovations View Post
    I have to believe there is a reason for all motorcycle mfg to have a very tight torque'd axle nut & still have a cotter pin in the axle. Perhaps it's a safety precaution in case the mechanic forgets to torque the axle nut or ~~~~~, but since the mfg go thru the expense of drilling a hole through the axle & adding a safety cotter pin you best believe they have a reason. Plus if any of these cotter pin less axles decide to test the top speed on a one mile sanctioned top speed run (usually on abandoned air strips) no axle cotter pin = no test run--period. (similar to arguing that your DOT helmet is just as good as a current Snell rated helmet--will get you No Where)
    Darrell
    May 2009
    Connecticut
    I noticed it said 160 in CD manual But I didn,t have a torque wrench that high so I Just Tighten it as Much as I can Just short of Breaking the Nut?
    Jul 2011
    Mitchell, Ontario, Canada
    You did not share what year your F3 is. But the 2015 F3s exploded parts view does not show one. So I will assume it does not need it.
    Oct 2017
    Pennsylvania
    Exclamation 2015
    Thank you for the diagram. I have 2015 F3-S. Based on the diagram the right side is supposed to have both nut(1) and a nut(43) after the washer(8) . Mine only has (1), no second one.
    Is this how you have it on yours?
    Sep 2015
    Cold Spring, MN
    Default Don'tPanic
    Don't panic! Trust me when I tell you yours is correct. Between my friends and I we have 7 F3S's, (4 2015's, 1 2016, and 2 2017's) and everyone is exactly like yours, including my new '17 Daytona.
    2020 RT Limited
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Oct 2017
    Pennsylvania
    Thumbs up Thank you
    Quote Originally Posted by Michaelscs View Post
    Got it. Thank you
    I just wanted to make sure.
    Jul 2011
    Item 43 is just a decorative plastic cap.
