Results 1 to 10 of 10
    May 2016
    Nashville, TN
    Default Headlight replacement
    I just replaced my OEM halogen headlights with Sylvania Silverstar halogen 9005's at a cost of about $30. I considered LEDs but the $95 cost stood in the way. Was this a mistake?
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    I wouldn't say it was a mistake. I was going to do the same thing until the post by "Joel the biker" about LED headlights he had bought.
    http://www.spyderlovers.com/forums/s...ker+headlights
    They cost about $32 or $33 and so far I'm extremely happy with mine!
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Default No
    Not a mistake you have upgraded and depending on the ryding you do you are fine. The whole brighter during daylite hours eludes me as many drive with polorized sunglasses have tinted windsheld and as I see it the best daylight defense is the neon vests. I use the same bulb and the light provided is all I need for driving in the dawn and dusk hours. I avoid night driving as much as possible.
    Greenville Tx
    I replaced mine with the Lamonster LED's very bright and more of a white light than the yellow ones it had. The only problem is they seem to be aimed too high and overshoot the close stuff. I need to run my fog lights to fill in. My fog lights are yellow light though.
    2017 F3 Limited
    Greenville Tx
    2017 F3 Limited
    Time will tell. I have not liked the low life of the OEM style bulbs on my 2014. After two burnouts--I replaced with LED's. The jury is out at this time.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Joerolwing View Post
    No. Compared to your OEM halogens the Silverstar gives a much brighter, whiter light. The tradeoff is that it will have a shorter life so be prepared for that.
    As to LED's, they are more expensive as you noted and experience has shown they don't last as long as LED's are supposed to last. I'd say if the Silverstars give you satisfactory light output, be happy with them.
    2014 RTL Platinum
    Danbury Connecticut
    It's not a mistake, just not the best choice.
    The Sylvania Siverstars are bright, but it come at the cost of longevity.
    They seem to last about 300 hours.
    For a car, that's a lot of night time driving.
    For a motorcycle, with the lights on during the day, that's maybe one season.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Jul 2013
    martinsburg,ohio
    I just replaced mine with Sylvania Siverstars.They have a one year warrenty
    May 2016
    Winnipeg, Manitoba, CANADA
    Default ST Headlights
    I did the same thing. Would do it again. Especially knowing that if my one spare bulb is used, I can always get another one very easily while on the road.
