Results 1 to 10 of 10
    Oct 2017
    Meridian, Texas
    Default New Owner - Fuel Cap Question
    I just purchased a 2008 Spyder GS SM5. Can someone tell from the pics if this is the new or old Gas Cap?
    Default Welcome. ..to the 🎪
    Not sure what those are but niether one is a can am gas cap. Not to say they are not fine as there are others out there....only difference I remember was the color of the gasket...
    Sep 2016
    clark county indiana
    Default it does look off
    if you need conformation , take it to a dealer in your area ... does it seal alright ?
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Quote Originally Posted by X2jetpilot View Post
    Looks like the old one
    check this out
    http://www.spyderlovers.com/forums/s...ht=Fuel+recall
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Aug 2012
    CO
    Old one I believe. I have the new one and it has a RED o-ring.
    JLohPhotos
    2008 GS , Millennium Yellow
    Oct 2017
    Meridian, Texas
    Default Looks like the old one to me also.
    Quote Originally Posted by eddieshep999 View Post
    check this out
    The problem is BRP customer service will not do any thing because the service history says the dealer the original owner used replaced it. I'm not super concerned about a 10 dollar part, but it makes me wonder what else they charged BRP for and didn't do.
    youngers: No it does NOT seal. I will check with another dealer. The one I stopped at wants $115.00 (1 shop hour) to "inspect" the bike and tell me what service they think it needs.
    Default YOUR ISSUE
    .... Is that STEALER in " NIGERIA " .............GOOD LUCK ......Mike
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    You have the old cap. It is identical to the one I removed from my '08 GS. I still have it & just compared it to your 2 pics. In small writing below "WARNING" it also says "fuel spray may cause injury"
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    The replacement caps were useless anyway because often after 18 months or so the mechanism goes in them and you find yourself stuck at a petrol station unable to remove the gas cap. Wouldn't surprise me if this happened to the previous owner and the went back to using the old cap. This may well be why BRP think its been replaced.
    If you are getting another it may be worth getting a Stant one instead. Can't remember the part number but I suspect someone else will.
    Oct 2017
    Meridian, Texas
    Default New parts.
    Quote Originally Posted by PistonBlown View Post
    Yeah I put a Stant fuel cap on it. Any time the bike needs parts I will opt for after market when available.
