Results 1 to 25 of 27
Thread: Spyder on ramps
    Jul 2017
    sarasota, fl
    Default Spyder on ramps
    Did a search for raising a spyder with jacks.
    Got some good info from an old thread.
    Now am interested in seeing what some of you have used for ramps to raise up the front for service.
    And hearing how ramps work for you.
    I learned about jacks, so please only talk about/show ramps in use.
    Please post pics and tell where you got your ramps.
    Active Member CA Railwhale's Avatar
    Aug 2016
    Sun City West, AZ
    Default Rhino Ramps
    Quote Originally Posted by ofdave View Post
    I use the same Rhino Ramps that I use to level my RV. Sorry I don't have any photos, but they are easy to use and raise the front of the bike about eight inches. That's just enough to get under it to work with a couple of inches of clearance. I ordered the ramps from Amazon, they are 12,000 pound rated and cost about thirty nine dollars plus shipping.
    Jan 2015
    Florence, Oregon
    Lightbulb Ramps?
    I have a very steep driveway that flattens out just in front of my garage, so I use two large cement blocks spaced to match the front wheel spacing with 2"x10" planks 6' long placed from the slanted driveway over the blocks. Drive down the driveway onto the planks, set the parking brake and the is level with plenty of clearance to drain oil. In flat country one could use three blocks with planks set so you would reverse onto the ramps and have the weight supported by the blocks. Just a thought and affordable.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by CA Railwhale View Post
    Ditto. https://www.amazon.com/RhinoGear-119...ds=rhino+ramps
    Turn down the audio to watch this; https://www.amazon.com/RhinoGear-119...ds=rhino+ramps
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Quote Originally Posted by MercerLake View Post
    I also have a sloped driveway that I use in this manner to obtain greater clearance when working on my vehicles. But, I use RHINO ramps, which seem to me a much safer option.
    2014 RTL Platinum
    Jan 2015
    southern WI
    Simple car ramps, Rhino or whatever brand will work fine. It's really not rocket science. For the most part, it's nice to have the bike up in the air and level...so for that reason it's also nice to have a lift. Just a simple one from Harbor Freight will work fine
    2016 RTS , Pearl White
    Feb 2013
    Northern California
    Default I use...
    I use the adjustable Leveling Blocks that I also use for our RV.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Mazo EMS2 View Post
    The single biggest concern with using a hydraulic lift is that there is no side-to-side stability once the bike is lifted by its single frame member. I found this out when removing the rear wheel for tire replacement. Jacks under the A-arm help, but can slip. I think ramps are the safest way to lift the front of the bike, and I use them to stabilize the front if I need to lift the rear to work on it.
    2014 RTL Platinum
    Jul 2017
    sarasota, fl
    good stuff so far
    a pic or 2 would be great
    Aug 2016
    Sun City West, AZ
    Default Jackstands
    I wouldn't work under anything supported by just a jack. Jack the Spyder up and use jackstands for support.
    Dec 2015
    Oakley Utah
    I do; I just didn't elaborate. Maybe should have.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    good stuff so far a pic or 2 would be great
    Geez, Louise ...
    2014 RTL Platinum
    Mar 2015
    forrest above Reno, Nv
    " A car only falls on you once" As I told auto shop students------and some still didn't get it.
    2014 RTS , Circuit Yellow
    Dec 2015
    Oakley Utah
    Quote Originally Posted by kaos View Post
    Well, maybe they figured that once they got past that first accident they would be home free. Kind of like waiting for that first scrape, ding, whatever in a new car so you stop worrying about it.
    2014 RTL Platinum
    +1
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    Went to Harbor Freight bought two set's of there ramps. These come apart if you need to I put two in front and one in rear.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Grayfox View Post
    2014 RTL Platinum
    Oct 2013
    Wood Village OR
    I use 3 ramps and back up on them, I also drilled a hole into my driveway and inserted a bolt thru the tip of the back ramp so it could not be pulled forward when backing up as the front wheels just follow but the power to the rear wheel wants to pull the ramp forward.
    2014 RTL , Black Currant
    Dec 2015
    Oakley Utah
    Quote Originally Posted by easysuper View Post
    Good idea.
    2014 RTL Platinum
    Feb 2012
    Spring City,Utah
    I also use 3 ramps,but I can't get my rear wheel to climb without spinning out so I just jack it up and slip the 3rd ramp under it.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Feb 2017
    Geez, Louise ...
    Oh yes. Those are the ones I have and find them to be well suited - so far.
    Apr 2016
    St. Charles IL
    I use the ramps from Harbor Freight. I run the bike up on the ramps then jack the rear up with a floor jack and place a cinder block under the rear wheel. This works great for me!
    Jul 2017
    sarasota, fl
    Geez, Louise ...
    thanks
    it wasn't that hard was it?
    we don't know the brand but they look like they work well
    Jul 2017
    sarasota, fl
    am glad to hear what you guys use, leaning toward the Harbor Freight
    any pics if a Spyder on the ramps?
    Mar 2016
    Highriver,ab.canada
    Made up ramps used 3 ply 2by6 then cut 45 angle to drive up on. Same as you drilled holes in garage floor insert 3 bolts to keep from sliding . Lots of room for oil change on F3T.
