Results 1 to 10 of 10
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default We may have mistakenly...
    ...put 20W50 Amsoil in a 2012 SE6 for an oil change. About 4.5 quarts of it... should we drain it and put in 10W40? Unsure about what to do....
    Jim
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Jun 2012
    Fairmont, Minnesota
    It probably isn't totally necessary but, I would change it. Excessively thick oil can cause real problems and with cold weather coming, it will possibly not allow proper lubrication when starting a cold engine. If you are not ever going to ride it in the cold, leave it alone until next spring.
    Sep 2016
    dilworth,minnesota
    should not hurt a thing as long as the engine and gearbox are lubricated and the clutch doesn't slip. Oil viscosity isn't as big a deal as people make it out to be.
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by BigGuy66 View Post
    Jim
    Ride it. It isn't going to hurt anything. As the oil level goes down in the 998 refill with the 10w40. You really will be just fine.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2016
    dilworth,minnesota
    rcturner is right about cold weather starting but as far as lubrication is concerned 20 weight oil should not cause a problem until temps are at or below freezing starting should not be a big deal at most temps at or above freezing
    Invalid Emails
    Apr 2017
    AZ
    20W50 is as viscous (flowable) as 20W at low temps and thickens to a 50W as temps rise. So you are starting your cold engine with what amounts to a 20W in it. No problem.
    Default I'm with them
    Your fine till your next oil change. I serviced bikes for years in Texas with 20/50w castrol and it gets cold there like in your neck of the woods. If it makes you feel better warm her up a few minutes longer....
    Default AMSOIL !!!!
    Amsoil is full synthetic oil .......... you could use their 20w/50 in the Artic and it would still flow .......... .... Mike
    Jun 2015
    Hobart, IN.
    Default Oil
    Jim
    It will not hurt anything, the lower viscosity is for cold weather. Unless you live in sub arctic weather you will have no problems..........
    Sep 2012
    Stetson, Maine
    I agree with above posters.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
