Results 1 to 9 of 9
    Aug 2017
    C'ville MO
    Default "new to the spyder" battery ?????
    Will this battery be ok on my 2012 spyder rt limited?
    thanks in advance.
    https://www.amazon.com/gp/product/B0...78MGMXY1&psc=1
    Jul 2011
    Mitchell, Ontario, Canada
    Not even close to big enough. It it has half the cranking amps of the OE Yuasa battery. Get another Yuasa http://www.yuasabatteries.com/batter...D=B191&vID=115
    Apr 2011
    GREENVILLE, SC
    Default Yuasa
    i recommend 3 batteries: YUASA, YUASA & YUSAS.....
    don't mess with 2nd rate anything... ALWAYS spend the extra few buck$, and you'll reduce your risk greatly of being stranded on the side of the road...
    jmho
    Dan P
    SPYD3R
    Less expensive is not always the best. OEM for me on all my
    batteries. Replaced the battery on the 2011 at the beginning of this season, and the 2014 gets one next season.
    Default There you have it....
    You can shop the price but not the spec's or quality...Try cheapcycleparts.com for one and ebay also has them. Google and you may find others just get the same one....
    Aug 2017
    C'ville MO
    Thanks Guys
    Jun 2014
    ny
    get the battery lamont carries
    Aug 2012
    Central Coast, CA
    Lamonster's garage sells batteries. They are Motobatt, which in the motorcycle industry are considered to be a very good quality unit. His prices are very competitive, plus you support the community.
    2020 RTL SE6
    minnesota
    That says it's the correct battery for a 2012 RT but it's not. Your battery should be a size 24, not 14.
