Results 1 to 10 of 10
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default Can anyone tell me about this....
    ...clutch handle seeming to hit the handlebar grip? There are marks on the handle from hitting the grip. Is there a way to adjust the handle travel distance?
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Jan 2015
    southern WI
    If I remember right, there IS. Is there a small dial at the front of the clutch handle. I think it adjusts the handle forward/back. Or, maybe it's just for adjusting for big/small hands and doesn't affect the pull distance...?
    2016 RTS , Pearl White
    Default Well....
    You can as far as reach and travel but regardless of the position you choose you can still pull the handle all the way to the grip. I like it all the way out so it is a minimum pull to operate and once out of first don't use it at all except for downshifting...
    Sep 2016
    clark county indiana
    Default big guy
    how many miles on your cycle ? is it really easy too pull the clutch lever to the bar grip ? ( wondering if your inner clutch is getting worn ) you should have some resistance with just a little pull on the clutch and should , I think , be able too change gears at a little passed the half way point of no pull too grip position ( check the fluid in the reservoir see if it is low might need to drain the fluid and put new fluid in --- good old you tube give you an idea ) I might be wrong , just something that might be going on ...
    Aug 2016
    Default Thanks for the suggestions...
    ... about the clutch handle travel. I now have some things to check on and I will do that. I am heading to our CMA (Christian Motorcyclists Association) Indiana State Rally on Thursday and I'm getting the byke ready for the (short) trip.
    Jim
    Oct 2013
    rome new york
    Don't need to pull back all the way to shift
    Active Member Jheck's Avatar
    Jun 2015
    sherburne, ny
    So you shift your manual shift like the semi-auto and have no problems? Or have I misunderstood?
    Aug 2012
    CO
    Quote Originally Posted by Jheck View Post
    You can with any wet clutch motorcycle transmission. Preload the shift lever near the rpm where you normally shift up, roll off the throttle a bit, and upshift with the toe. Do it right and it's smooth and fast. Downshifting is also possible but way harder to get it right.
    JLohPhotos
    2008 GS , Millennium Yellow
    Apr 2017
    North Central Florida
    Quote Originally Posted by BigGuy66 View Post
    NO, you should NOT try to adjust anything just because of that.
    It is perfectly normal for the clutch lever to hit the hand grip.
    If anything, this just means that the grip material is getting old.
    If you must do something, clean off the back of the lever and then don't worry about it.
    Question: When is the last time you changed the fluid in that system?
    It requires periodic servicing...
