Results 1 to 18 of 18
    May 2013
    Columbia, SC
    Default Front trunk latch
    I have a 2012 RT-S with about 7200 miles on it and my front latches is not working properly. I have to continue pressing it to get it to final release. Before I take it the local dealer for repair, I was hoping to see anyone else experience this issue. Also, I was wandering what the cost of repair would be?
    Default FRUNK LATCH
    Quote Originally Posted by BlueRTS View Post
    They are easily adjusted .... do you have a 10mm socket ( a deep one works best ) ...if so I'll tell you what to do ....Mike
    Default Adjustments....
    First off does it latch easily..? Or do you have to press it down to latch..? The pin on the frunk lid is adjustable, loosen the lock nut and back the pin out a turn or two then test it. When you get to the right point tighten the lock nut to secure the pin in place...
    washington state
    After you adjust it make sure you spray the latch with wd40.
    Apr 2017
    Queensbury, NY
    Not to steal this thread, but my frunk opens normally but is difficult to latch. (I have to press it down ... with some force.) I see two nuts on the pin - one near the lid and one near the end of the pin. Which nut are you referring to? And in which direction do I need to move the pin in my case? Shorten the pin or lengthen it?
    Thanks!
    Apr 2017
    North Central Florida
    Quote Originally Posted by jerpinoy View Post
    Sorry but that's NOT a good idea.
    WD dries to a sticky film and at that point is NOT really a good lubricant.
    Some silicone lube might actually solve the problem without mechanical adjustment.
    I suggest you try that first.
    Feb 2012
    Spring City,Utah
    OK Mike so assume we have or can easily obtain a deep 10 mm socket. What do we do next?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Default FRUNK LATCH
    OK as you face the open Frunk .... look at the Latch .... there are two 10 mm nuts ( they are on fixed studs like on your wheels ) ...... You should remove the left plastic cover to get better access ..... and the DEEP socket is better for the ACTUAL Removal of the Latch !! ... An open end wrench will work for a little adjusting ...... So you are probably doing this because the hood doesn't latch EASILY or the hood doesn't open EASILY ...... so if you loosen the bolts enough to put a screw driver at the front you can LEVER it up a VERY little .... tighten nuts and see if that was enough ..... if not loosen and lever it up a touch more ...again tighten nuts .... keep repeating until your are happy with how it works ................PS as someone said don't use WD40 as a LUBRICANT ..... it's not a Lubricant , it's used to LOOSEN things but doesn't work as a long term lubricant............ Mike
    Feb 2012
    Spring City,Utah
    Thanks Mike, worked like a champ. I have to say I am not very pleased with the work my dealer did on this job. He has been good in the past but the quality this time was not up to par. It is too much effort to go back to him for the correction but he will hear about it.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Default FRUNK LATCH
    ..... Glad I could help you with this ..... the adjusting is hit or miss because you don't want too much and too little won't work ..... sometimes if your really Lucky you get exact the first , Because I was doing FRUNK LATCH RELEASE - PULLS , I did a few dozen complete removal and re-assembly .... and even with that experience it was still hit or miss ....... Mike
    May 2013
    Columbia, SC
    Default Frunk Power Latch
    Ok, my issue may be with the power latch that unlock the frunk. I have to continue to press the button to get it to pop open. How can I tell if its the power button or if the latch needs adjustment without taking it back to the dealer?
    INDIANA, USA
    Default Front trunk lid
    I have issues with the front trunk lid sealing all the way around. Standing, at the front, the right half will not go all the the way down on the seal. Dealer said the the lid was warped and would check. BRP said they did not have a fix. Ride 2016 RT Limited HELP Thanks, Little Blue
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default I did exactly what Mike said...
    ...my frunk now works easily to close and to open. Thanks - But... what do I use to lubricate this system and where do I use it?
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Default LUBRICANT
    Quote Originally Posted by BigGuy66 View Post
    I prefer CRC Heavy duty Silicone .... after it dries it leaves a nice Film , un-like White Lithium grease which will also attract CRUD ..... Folks mis-takenly use WD40 which isn't a lubricant ...it's good for braking things loose but it's only temporary , imho ..... Mike
    Apr 2017
    Quote Originally Posted by Little Blue View Post
    Of course there is a fix. Replace the lid.
    If there is no sign of purposeful damage and it's still under warranty, THEY should cover the cost.
    Aug 2017
    New Jersey
    It was probably me that advised against WD-40. It does free things up so people think whatever you used it on is now lubricated. It is obviously wet when you spray it on, so people assume it's lubricated, but it dries rather quickly, leaving nothing behind.
    Default WD40 VS. SILICONE SPRAY
    Quote Originally Posted by classicvw View Post
    ... also ..... the silicone goes on wet also, and dries pretty quick .... but the silicone leaves behind a slippery film .... Mike
    Apr 2017
    It was probably me that advised against WD-40...................but it dries rather quickly, leaving nothing behind.
    Not exactly. It leaves a sticky film.......that is designed to be a Water Dispersant (WD).
