Results 1 to 12 of 12
Thread: Lugnuts
    May 2017
    North East, MD 21901
    Default Lugnuts
    What size lugnuts are on a Spyder and the best way to get them off without breaking or striping the lug?
    Invalid Emails
    Oct 2015
    morgantown west virginia
    21mm or 13/16". good socket with a breaker bar
    May 2017
    Thank You
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Lugnuts are 21 mm on Spyder
    Lugnuts are 21 mm on Spyder, and a 13/16 spark plug socket is thin wall and will fit a little tighter and do fine to remove and then when you go back with clean wheel and nuts, torque to 77 ft-lb and you'll be good to roll.
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Use a six point socket for best grip on the nut.
    Oct 2011
    Kalamazoo, Mi
    Default Lug nuts
    And turn them left loosey
    2018 F3-T
    2018 F3-T , Pearl White
    May 2017
    Mesa, Arid-Zone-A
    I like even numbers and torqued mine to 80#s. I believe to specs call for 80 +/- 3#s
    Semper Fi
    Linden, CA
    Easiest way is with an impact gun air or elect.
    21 mm six point socket or 13/16
    Sep 2016
    Chillicothe, Oh.
    IF you know what you are doing. I have made a lot of money over the years from folks who went after their bikes with a shiny new impact gun
    2015 RT , Black
    May 2017
    Default Lug nuts
    The reason I asked was I only had a 3/8" rachet, I put a big wrench on the end of it and broke the rachet. Had to borrow a 1/2" to do the job. Got my centramatic balancers installed ok.
    Active Member Hey Yu's Avatar
    Mar 2016
    Australia
    Quote Originally Posted by Ed Evans View Post
    Now you have an excuse to get a better ratchet!
    May 2017
    Mesa, Arid-Zone-A
    Eight foot-pounds and 3/8 inch Chinese steel do not play well together.....
    Semper Fi
