Results 1 to 25 of 37
Thread: XM radio
    Feb 2012
    Spring City,Utah
    Default XM radio
    I had the BRP XM radio installed by my dealer. I can not find how to bring up the "0" channel to be able to see the ID # to activate the radio. When I get to the screen where the channel #s should be there is nothing there.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Feb 2012
    Spring City,Utah
    I did find this in an old post in RT Shop talk.(search does turn up a nugget now and again)
    http://www.spyderlovers.com/forums/s...t=radio+tuning
    check out post # 35 and 36. My problem is there is nothing in either the category screen or the channel screen.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Feb 2012
    Spring City,Utah
    Bump
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    Is it listed in the paperwork that came with the radio?
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by SPYD1 View Post
    No it is not.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Apr 2017
    North Central Florida
    The installing dealer should be responsible for letting you know what you need to activate the unit.
    If they can't do that, they shouldn't get paid.
    Very Active Member cyclelover63's Avatar
    Mar 2011
    Big Sandy, TN
    https://listenercare.siriusxm.com/ap...41/kw/CAN%20AM SIRIUS RADIO has a chat option that may help you find your ID number.
    Feb 2012
    Spring City,Utah
    Thank you for all the replies. I know how to get the ID,just tune to channel "0". The problem is that when I bring up the screen that is supposed to show the categories and the channels there is nothing there,the screens are blank. I am looking for a reason or a remedy for this
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Sep 2014
    USA
    Are you getting a good Sat signal to the antenna?
    Feb 2012
    Spring City,Utah
    I don't know. The radio is not giving me a no signal warning
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Sep 2014
    USA
    You should at least get the preview station on channel 184 or channel 1. I believe it is. Then you know you got a signal for sure.
    Where is the XM antenna mounted?
    Nov 2013
    Oro Valley Arizona
    I am assuming you have already acquired a subscription from Sirius/XM. I use my Garmin 665 and XM-40 antennae for XM radio. Speakers or
    Bluetooth headset.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Apr 2017
    Quote Originally Posted by jaherbst View Post
    I think that is a bad assumption.
    You need the radio ID number BEFORE you get the subscription.
    A couple of rather obvious solutions have been offered already:
    Call Sirius/XM or contact the installing dealer.......and yet the OP seems to be ignoring both suggestions.
    Feb 2012
    Spring City,Utah
    Y
    The antenna is mounted on the top lip of trunk just under the lid. That is where the installation instructions say to mount it.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Feb 2012
    Spring City,Utah
    now don't you be making "bad assumptions" there Easy Rider.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Sep 2014
    USA
    Is it facing up or down?
    You may not get a good signal under the lid of the trunk. I got rid of the puck type and got a antenna type for the XM.
    Try moving it out of the trunk and face it upward towards the sky.
    Like I said you should have something playing on channels 1 or 184
    Feb 2012
    Spring City,Utah
    It is facing up right now,when I get home tonight I will see what happens when I move it out from under the lid.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Sep 2015
    Parkesburg,Pa
    I have the brp sirrius module which was installed by the dealer,my antenna,puck,is on the shelf under the lid in the trunk also.I have no recepition problems,as stated you should get a preview channel on 1 and ID on 0.If your not getting anything I would revisit dealer to make sure they connected everything correctly.
    Feb 2012
    Spring City,Utah
    I will have to take back to the dealer, but that is in the future as he is over 100 miles away and a day off work. I am hoping for a solution I can apply here or maybe I am not accessing the radio right.It may be a vein hope but at least it gives me something to do until I can get back north.
    Thank you all for your responses.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Apr 2017
    Well you have not RESPONDED to either of those suggestions.......so what else should we think ??
    Sep 2014
    USA
    any updates on this topic??
    May 2017
    Boulder City, NV
    i have the same radio....antenna located just like yours and it works great...i don't remember where i found the radio id, but i suggest you phone em up.
    Mar 2015
    Tampa
    Did you change the radio from FM to XM in the menu
    Aug 2017
    arkansas
    Quote Originally Posted by gmuratides View Post
    or aux
    Feb 2012
    Spring City,Utah
    yes.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
