Results 1 to 25 of 40
    Nov 2015
    Tinley Park, Il
    Default dust cap popping off
    Hi, My dust cap (I think it's called that) keeps popping off. Anyone else having this problem and will it cause a problem?
    Thanks, Mike
    Houston
    BRP has some really cool machined aluminum ones that bolt on.....
    never miss the chance to farkle ;-)
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Mar 2016
    Highriver,ab.canada
    Default Dust cap problem
    Quote Originally Posted by wmh9680 View Post
    Thanks, Mike
    Same thing on my F3T, run a small amount of silicone bead around edge. Works good no more lost caps.
    Yup! One missing on my "nanner." Thanks for the reminder and the possible solutions.
    Mar 2017
    Salisbury,NC
    yes, one side came off my RT Ltd also
    There was a thread on this topic almost three years ago when I bought my Spyder. I did as one poster suggested and put small dabs of RTV silicone on the tabs that hold the caps in place. It is an excellent solution; mine are still in place and show no signs of coming loose.
    Sep 2016
    Chillicothe, Oh.
    What he said.
    2015 RT , Black
    Default Oh yeah....
    you can walk down a line of spyders and not find one that has them both. Unlike the rear axle covers these spin. Lamont has some that set screw on and I have had for years. Maybe some silicone would keep them on longer....
    Nov 2015
    Tinley Park, Il
    Thanks, I just put on my Show Chrome trailor hitch and rack so I now have 2 spares. Thanks, Mike
    The front dust caps on the RTs, 2014 and later that I know of, do not spin. They are mounted to the L & R knuckle assemblies which are connected to the upper and lower A arms and tie rods and to which the hub assemblies are bolted.
    Sep 2016
    clark county indiana
    Default Wow
    you mean those are covered ? did not even think about it , although I do watch the spin action as I ride ... can some one post a photo of the chrome spin on type ? thanks
    Sep 2016
    went out to double check , yeppers double gone
    The part number is 705401100, wheel cap
    Active Member HankD's Avatar
    Jul 2017
    Huntsville Alabama
    I must have a defective trike. Mine are both still attached after about 2,000 miles. 2017 RTS.
    Sep 2014
    USA
    They sure are mounted pretty crummy. I am afraid to touch it or they will fall off
    Sep 2014
    USA
    Sep 2012
    Stetson, Maine
    Mine have been gone since 2012, and 50,000 miles later.
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    You need to takes yours to the shop and have one remove quickly
    Nov 2015
    Tinley Park, Il
    oops, the rear caps are totally different and the one that falls off has a couple of tips boken off. Mike
    Active Member wd8ajj's Avatar
    Las Cruces NM
    On my 2014 hitting a pot hole or a really bad road I have lost a few front. Bought about 6 for 4.95 a year ago and have 2 left. Funny that after they rebuilt our freeway I lost 2 going over a "new" bridge! Road was about 3 in higher than the end of the bridge! Great craftsmanship. Oh ya the construction co was from Mexico and one day just never showed up for work. Defaulted on there contact. talk about a mess.
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    I noticed last week that I'd lost one. New one due in at the dealer any day now. Will silicone both.
    Active Member SpyderSteveFL's Avatar
    Dec 2015
    South Florida
    Or get fancy and put Glo Hub rings...
    NEW/CURRENT (Wife's Bike, I ride Goldwing/Africa Twin)
    2023 RT Limited Petrol Blue Metallic
    Working on the upgrades... so far... Show Chrome Isolator Fuse Block, Tackform Adventure Wireless charger phone mount
    OLD/TRADED
    2015 RT Limited Intense Red Pearl
    Farkles: Ultimate Tallboy seat, FOBO, JT Dash Mount, Lamonster Spyder Cuff, Kradellock, TricLED lighting - fenders, A-Arms, saddlebags, run/brake, Custom Dynamics high brake light, brake modulator, Drink2Go passenger, MUTH turn signal mirrors, Bajaron sway bar, Kuryakyn ISO grips, SpyderTV front grilles & rear trunk organizer, homemade trunk light
    Pending: Elka shocks, Yokohama S Drive rear tire, EVO 595 front tires, Centramatic balancers, Neutrino black box
    Jul 2015
    Saint Michael, MN
    After losing two, I used some 3M trim adhesive and not had to replace yet.
    Gunner
    Feb 2017
    Gwinnett Co Georgia
    I was concerned because my 2012 RT A&C is missing both front wheel caps and the axle nuts and bearings are exposed. That is until I looked at a parts diagram and discovered that there is no such part on a 2012. So I wonder if those caps are truly necessary.
    UPDATE: on further research I determined that the inner wheel caps were not added until the 2013 model (i.e. 2010-2012 did not have them). I might assume the same part would fit on a pre-2013. Does anyone have an opinion whether I should add them on my 2012? It still has low miles (~7000) and so far the front wheel assemblies are very clean and almost new-looking.
    Sep 2016
    Default i bought the 2013 or 2014
    Quote Originally Posted by KLo5591 View Post
    I picked up a couple dust covers for the 2012 using the 2013 numbers they do not work , { start cheep and work my way up } I did how ever see a nice looking bolt on type , using new bolts , the dust cap is bolted onto the frame where the fenders are attached , new longer bolts come with the cover ----> I am looking for the item as I type forgot where I saw it will check back in when I found them again
