Results 1 to 22 of 22
    Mar 2016
    Santo, Tx.
    Default 2015 RT Limited, Heat coming up the front of the seat
    The other day the wife and I went for a ride, it was 104 outside when this happen, after riding for about 30 minutes the heat started coming up at the front of my seat getting really hot on the inner thighs...........any suggestions.......
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Get used to it. Always gets hot "down there". Along with the hot riding conditions, probably hotter than usual.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by tmarsanto View Post
    There has been discussion on other threads about installing the 2013 air scoop kit provided by BRP as a fix to the overheating problem in those earlier years to the later models to help relieve the heat in the cockpit area. I have a 2014 RTL and purchased the kit on the advice of this forum but haven't installed it yet so can't tell you how well it works.
    http://www.spyderlovers.com/forums/s...715-Air-Scoops
    2014 RTL Platinum
    Jun 2010
    Las Vegas
    Your Spyder is trying to tell you that it is too hot to be riding.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    I installed the 2013 air vents on my 2015 RTS works good lowering the Temperature on my seat
    If it's 104 outside : what do you expect?
    May 2016
    Cartersville, GA
    Install the scoops as mentioned above.... I have a 2012 RT and my friend has a 2014 RT. I installed scoops on both bikes and the heat is gone.........................20170526_121406.jpg
    Active Member Spider-man's Avatar
    Mar 2017
    San Antonio
    Another vote for scoops. Hot air no longer coming from the glove box, and the engine on my 2010 even runs cooler.
    Mar 2016
    Santo, Tx.
    haha...........probably so
    Jul 2011
    Oklahoma
    Just be careful when riding in that type of heat. It can sneak up on you; speaking from experience. If you do, take plenty of breaks and TONS of water and electrolytes. Ride happy but ride safe...
    Mar 2016
    Santo, Tx.
    Will check it out......thanks
    Mar 2016
    Santo, Tx.
    Quote Originally Posted by BitSlayer View Post
    Thanks for the info...........
    Faribault, MN
    I have a 2013 RTL that has had the Heat Recall done, I can carry a chocolate bar in my glove box (White bike) and not have them melt into a puddle. I also did some other mods that were recommended for 2013's, but I think the '14 and later reverse radiator flow takes care of that.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jun 2015
    Hampton Roads, VA
    Default Yes.. This!
    I installed on my 2016 RTS and far more comfy now. Comes with heat liners for the tupperware. Glove box doesn't try to melt my phone anymore too! Taking out those big side supports and replacing with bars allows tons more air through under the seat!!
    It is scary as heck to install, as you have to drill holes with no template, just guessing. But they get covered up. As you will see in the thread, the plastic used is NOT all that great - I used plasti-dip, like 10-15 heavy coats, 1/2hr in between. Holding up wonderful.
    Steve
    May 2017
    Mesa, Arid-Zone-A
    I just removed the lower (OEM) wind wings. This allows for more air flow over my knee area. When cool weather returns, the wings go back on.
    Semper Fi
    Oct 2011
    Jacksonville,Ar
    I put the vents on my 2011 RT and it really helped with the heat.
    I have the adjustable lower air deflectors which helps.
    15 rt , yes Black
    Oct 2014
    Bryan, Ohio
    Default Air Scoop Kit
    I installed mine a while back and it is a diffident improvement. Well worth the cost and the work to install it.
    Jul 2013
    Vestaburg Michigan
    For all of you that gave a negative review of the 2013 rt. Suffer! It is the cooles bike out there withe recall done!
    I would definitely recommend the scoops for all ! You won't believe the difference!
    Mar 2014
    Midlothian, Texas
    We cut an old windshield Sun shield to fit under the seat. Keeps the engine heat off the seat. Much cooler
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    If you ever replace your seat, get a tallbox or other extra length seat. Being and inch or 2 back from the heat has kept my chestnuts from roasting on the open fire.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    indpls in
    Default PUT THEM ON
    my wifes and she loves them not that big a deal to install if you have a good dealer tape up your panels where cut and holes go they have a template c if they will mark cut for you
    Apr 2012
    Northglenn Colorado
    I am feeling this same thing on my 2017 F3T Heat coming up from the engine to the seat area and on my right leg from the thigh to the ankle. Did not feel this on my F3S. Does not even have to be that hot out. Anything from 85 degrees and up I start to feel it after about 10 min.
