Results 1 to 25 of 31
    Jun 2013
    queens ny
    Default here is another one fog you smart people
    Jun 2013
    queens ny
    my answer is in the title
    Sep 2016
    LI NY
    "F"
    2010 RTSM5 , stock Stock Silver
    Jun 2011
    upstate ny
    Quote Originally Posted by Zip View Post
    "F"
    X2
    D,E,G, and H will never see a drop of water...
    A,B, and C will never get water above their outlets...
    Bryant, Arkansas
    F
    ​Cruzr Joe
    Jun 2014
    ny
    My money is on H when i stand above & pee in it
    Jun 2015
    Hampton Roads, VA
    Default Hmm...
    "L"
    Jun 2013
    queens ny
    i used the word fog, because the 3rd letter is G and that is my answer
    Sep 2016
    LI NY
    Quote Originally Posted by cuznjohn View Post
    D is blocked off so G will never see any liquid
    Jun 2013
    queens ny
    yup your right, i didn't see that
    Jul 2017
    Ramona, CA
    A as the outlet is not big enough to continue flow vs the amount in f water entering.
    Oct 2014
    cohoes ny
    without filling it i think "L" will be pretty full before "F" ?
    Jul 2011
    Oklahoma
    It has to be either K or F. I thin "K" will fill before F does to "K" is my vote.
    Sep 2016
    LI NY
    Quote Originally Posted by Kwalsh View Post
    L the water goes directly out the bottom before it is filled. it then starts to fill F from it's bottom. since F is lower it will overflow before L can completely fill.
    Active Member jerrydonna's Avatar
    Jun 2017
    Suffolk Va
    im a G man
    2012 , java
    Sep 2016
    LI NY
    Quote Originally Posted by BitSlayer View Post
    J feeds I which feeds K, the water in J needs to be up to the inlet of I before I will start to fill but before it can do that J will start to empty on the right side thus filling L which feeds directly to F and since F is lower than L, F will fill first.
    K will never see a drop of water...
    Because J will not fill above it's outlet into L; the water will not rise above that same point in the oulet that runs into I.
    So K will remain dry.
    Another "brain freeze," I need more coffee.
    more coffee!
    But what ends up happening first:
    An empty coffee pot, or a full bladder?
    more coffee!
    Yes.
    Nov 2014
    TriCities, WA
    I'm thinking G, C's lower outlet should empty before J can fill.
    Jun 2013
    queens ny
    Nov 2015
    Myerstown, Pennsylvania
    I counted 20.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
