Results 1 to 23 of 23
    Active Member JonYiong's Avatar
    Singapore
    Default Right palm gets numb - will bar-end weights help?
    Hi guys, my Spyder is an ST-L 2013.
    My right palm gets numb most of the time when I travel 20km and above, with an average speed of 90km/h. I have added foam grips and I'm quite relaxed on the grip.
    I don't wear gloves 'cause I don't feel comfortable.
    My guess is that this is due to the vibration of the belt.
    I Checked with Doc, but he doesn't have any tensioner for the ST's.
    I Wonder if by adding handlebar end weights, will it solve the numbness of my right palm?
    Do share if you have the same experience and have found a solution to counter it.
    Looking forward to hearing from you.
    Thanks in advances... Cheers.
    Active Member vampyregirl's Avatar
    Jun 2011
    Toledo, OH
    Mine does too. I bought the Kuryakyn throttle boss grip. Has a palm rest that helps!!! If I feel my hand getting fatigued, I rest the heel of my hand on it. Works pretty good!!
    Magnesium 2011 RS SE5
    Feb 2009
    Ceresco, Michigan
    I had this like crazy on my 2008 GS. Could only ride for about an hour and hand was totally numb. Related to carpal tunnel problems.
    I put on a Throttle Meister which acts kind of like a cruise control. Worked GREAT. Without that I never would have been able to put 75,000 miles on that Spyder.
    Both my 2012 RT and my 2015 F3 have cruise... so no longer an issue.
    If the ST you have is fly-by-wire then you can probably add cruise for a reasonable price....
    Active Member djhobin's Avatar
    Costa Mesa, CA
    My right hand use to go to sleep on me. I purchased an Atlas Throttle Lock and so it is working fine.
    If go to You Tube and put the name in the search. You can view it there.
    2013 ST , Black
    Singapore
    Quote Originally Posted by Firefly View Post
    Thanks for your advice.
    ST-L do come with cruise control.
    is just that Singapore is a very small country, ironically the moment i switch on the cruise the next few moment i need to switch it off to bring the beast to a stop.
    Feb 2017
    Mobile, Al.
    Go to you tube and google stretches for carpal tunnel - do them 2-3 times per day - it will improve!
    Next, buy yourself:
    http://www.ebay.com/itm/Throttle-Roc...53.m1438.l2649
    or some variation - they are sold on ebay and amazon - I don't know if our vendors here on the Forum carry these. The best attach with Velcro and stay the tightest.
    Dec 2008
    Syracuse, NY
    The first place I'd stop would be with my primary care physician to determine any physical/health issues. Not every numbness is caused by carpal tunnel.
    By the way, I had an issue with vibration thru the handle bars with my 2008 GS, and in my case I added bar end weights, which had to be cut to fit because I have risers; I also do not have carpal tunnel. The weights took care a good part of the problem.
    Bar end weights, and try some padded finger-less gloves
    (You'll get used to them! )
    Singapore
    Thank s for the suggestion.
    Would prefer the bar end weight option.
    Any good & nice bar end weight to recommend?
    Cheers
    Apr 2012
    Northglenn Colorado
    BRP used to sell the bar weights for the RS but they don't anymore. When I had an 2012 RS had the same problem and purchased the set of weights from BRP. I think I got the last pair ever made. Took them off because it made no difference. Finally put on the throttlemeister on to rest my hand and that worked great. Sounds like this will not work for you.
    Nowhere
    If it is carpal tunnel, changing the position of the bars may help ease the angle that is causing the pinched nerve.
    "If you can't be a good example, then you'll just have to be a horrible warning." Catherine Aird
    Active Member Air Wing Guy's Avatar
    Jan 2012
    Ohio
    Default Baker Built has ST belt stabilizer
    http://www.bakerbuiltairwings.com/pr...php?prod=SPYBS
    Here at Baker Built we have a belt stabilizer for the ST. If you are interested or have any other questions please feel free to shoot us an email at info@bakerbuilt.com. We have stabilizers for the RT's, F3's, ST's, and RS's.
    Jun 2013
    queens ny
    mine started as soon as i broke up with my ex years ago
    Dec 2008
    Syracuse, NY
    Quote Originally Posted by cuznjohn View Post
    Switch to your left.
    Jun 2013
    queens ny
    i forgot to say that i started riding more after we broke up
    Jul 2017
    sarasota, fl
    Had similar issues in the past.
    What was a big help to me was increasing the grip diameter.
    Tennis racquet wraps did the trick.
    I used the thicker ones w/ foam backing. get Them at Wally World for about 5 bucks-takes 2, one each side. Easy to install and just cut to length.
    Expect to be riding a Spyder in the next week and that will be the first thing I add.
    Likely that will be the least expensive thing I add.
    Singapore
    Btw is it ok to keep the cruise swith ON all the time so that I'm able SET/UNSET cruising mode as and when i need?
    Is it advisable to switch the cruise to OFF before I kill the engine?
    Northern Kalifornia
    Default Me too
    I had the same thing happen to me when I rode my bicycle. Didn't know it but there is a nerve that goes through the palm and to the middle finger. I got special set of grips that have a protrusion whereby I can rest the heal of my hand on the grip and take the pressure off my palm and not irritate that nerve. You can get those grips for just about any handle bar out there. Had them on my HD when I sold it.
    Feb 2017
    Mobile, Al.
    Default do the stretches!
    Quote Originally Posted by JonYiong View Post
    Cheers
    did you do the stretches ? did you look up some stretches?
    some times it is the free and easy things that works the best
    Default CRUISE CONTRL
    ... This will answer your Post # 5 also ,unless there is something different about Your cruise control , when you touch the brake it goes OFF !!!.... You can keep the switch on ALL the time - I do - not an issue ......... Mike
    Singapore
    Thank you all for sharing..Cheers
    May 2017
    Central Texas
    Default Gloves!
    CTS Stretches, Gloves, & use a throttle lock or cruise.
    I recommend ALWAYS wearing gloves, the first thing to hit the ground.... Hands, Head, & Knees... Protect Them.
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by djhobin View Post
    If go to You Tube and put the name in the search. you can view it there.
    Just added one to my 08 Spyder. Been so much rain haven't had a chance to test it out. A little pricey, but when you need to rest the hand it is worth it.
    David
