Results 1 to 14 of 14
    Jul 2016
    South Carolina
    Default Front tire vibration
    I have had a front tire vibration since I bought my 2016 RTS a year ago. I have put on a tensioner, replaces tires twice, had the all balanced and 3 wheel aligned. Its had new rims and tires put on it today and it still vibrates at 74 to 80- MPH. I have replaced the front end with a baja ron bar as well. I run the tires at 20 pounds in the front and 29 to 30 in the rear. BTW, I got 14k miles out of my rear tire! I don't know what else to do with it. Its done this since day one and Can Am has no idea whats wrong.
    Has anyone else had this problem? Does anyone have a fix for it?
    I have had this bike in the shop for this problem more than a dozen times. Anyone have an idea?
    Claimbo
    2016 RTS , GPS, entertainment cable. Outlets in trunk and trunk. White
    Faribault, MN
    Dynamic Balancers from LaMonster or TricLED, try just the front set and see if they don't smooth it out. They did for my Spyder running PPA wheels with no wheel weights even.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Default FRONT VIBRATION
    99% of the time it is caused by tire imbalance ( rarely wheel imbalance ) however if you have Kenda tires it could very well be the tires ..... they are known to have defective tires frequently ..... or whoever did your tire/wheel balancing didn't know how to do it ........ Mike
    Wot 'e ^^ says!! If you are still running Kendas, then that's most likely gonna be your problem!! Toss them & get some quality tires!
    I reckon you'll be surprised at how well your Spyder CAN feel & behave once it's got some good rubber under it!
    Jan 2015
    southern WI
    Did they check other mechanical stuff like bushings, bearings, rear tire balance, rear rim, rear sprocket, front sprocket, the drive belt...etc...? Could there be a body panel loose underneath somewhere?
    2016 RTS , Pearl White
    Jul 2016
    South Carolina
    I tried that. It didn't work. Thanks anyway.
    Jul 2016
    South Carolina
    I saw the tires being balanced. They were done correctly. Its not balancing. This is the third set of Kendras. I can't imagine all three sets and rims can be bad. Thanks anyway.
    Jul 2016
    South Carolina
    Quote Originally Posted by Mazo EMS2 View Post
    Yes, they checked it all. I just had my 13k maintenance . Everything has been has been checked. Its supposably all good.
    Sep 2014
    USA
    You know how many times I had my tires/wheels balanced and they were still not right.
    Finally the last place did them right
    I went with a road force balance ..Locate one of those machines and someone that knows how to use it and you should be better. Oh and they will need a small cone for there machine most shops don't have the small cone.
    I bring one with me and have them balance the Spyder wheels that way.
    Stock wheels maybe the problem as I went with a whole different tire than stock and same results until the balance was corrected properly
    good luck
    Active Member davehirst's Avatar
    Feb 2017
    Christiana PA
    Default Vibration
    2015 RT S, had the same problem. Dealer tried different wheels off of a demonstrator they had in stock the the problem went away. They replaced the tires, balanced and lazer aligned and problem went away. I feel your frustration, as mine was similar. By the way they put kendas back on. They don't use anything else they said. Have 4000 miles on them and they still run nice. I have 13500 on the rear Kenda and still have tread. It will need to be replaced end of season, but seems ok to me. (By the way, I looked at the wheel weights on the front tires they installed and the left one has A LOT of stick on weights, but again, runs fine. Just can't see a new tire needing that much weight. )
    2015 RT S , None Tried one, but took it off. Didn't like it Black and Silver
    Active Member wd8ajj's Avatar
    Las Cruces NM
    I just replaced my front tires to Federals and removed the Vee brand. What a difference. The Vee tires would shake the front end something fierce , even with Lamonsters balencers. Talking around found out that the Vee tires are made as bad as the OEM's are. Out of round and never be able to balance them.
    After 2 months of fighting front end problems will NEVER buy Vee brand tires again. There even made for the Spyders. Wonder if they make the Kendas under contract.......
    Panama City Beach, FL
    kendra's suck. get rid of them and you'll love your bike again
    United States
    I have Federals on the RT and love them. Just bought another set for the F3. Kendras suck.
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    Another vote to toss the Kenda's. You will be amazed at the immediate improvement in smoothness and ride quality. You can order Federals, Continentals Yokohamas and so on and take the wheels and tires to a local tire shop to mount and balance them.
    2016 F3L , Big Bike Parts Black
Tags for this Thread
