Results 1 to 18 of 18
    Dec 2016
    Iowa
    Default How useful is Eco Mode? How easy to learn when to shift?
    New driver, how useful (and accurate) is it to learn when to shift?
    2016 RT Limited , Black
    Apr 2017
    Enfield, CT
    Quote Originally Posted by Tyris View Post
    For me it was kind of useless. If you shift when it tells you, it will result in better gas consumption but super clunky, crappy shifts. Lets face it, most of us arent really watching the fuel consumption too closely, which im pretty sure that the intention of eco really is.
    I turned that off and found that shifting at 4000 rpm's is the sweet spot. Extremely smooth shifts. And for downshifting 3000 is the best for our F3L. Nice seamless shifts.
    Jan 2015
    southern WI
    Total waste of technology if you ask me. Useless feature....Just run her up to 3800-4200 RPM's in each gear and then shift up.
    2016 RTS , Pearl White
    I don't use it. It will save you about 1 mpg if you use it faithfully and shift when it tells you.
    I am guessing you have a 1330. The "happy" place is 3500 rpms or so on mine--yours may be slightly different. You will get used to the engine sound and shift accordingly.
    Also, I do not like the distraction of having to look for the green arrow telling me when.
    PS. Thanks for bring up the subject. I can do my usual rant. Keep the eco-mode and give me back my electronic trunk release.
    Jun 2017
    Albuquerque, NM
    FWIW, on page 31 of the owners manual it states, The ECO setting reduces fuel consumption by limiting throttle response and maximum throttle opening to maintain an optimal cruising setting. When I first picked mine up it was engaged. I had a hard time passing vehicles as the Spyder felt like something was wrong with the power output. Once I read the handbook, I shut that crap off and now have full throttle response and maximum throttle opening. Don't use it unless you want a loss of power. To get rid of it simply press the mode button for 2 seconds when in the main screen..
    Active Member Marcy's Avatar
    Leesburg VA
    Default Agree
    I agree with all the previous posts. I do however keep it on as it seems to remind me when I'm in annoying traffic. If you are learning don't rely on it, listen to the engine, it's a good habit to get into. Using the ECO is a crutch, don't get use to it. You need to look where you are going not focusing on the dash. Good luck and ride safe.
    2019 F3T , Blue
    Mar 2015
    forrest above Reno, Nv
    I NEVER use it.
    using the ECO mode caused::::::: Kaos
    2014 RTS , Circuit Yellow
    Jun 2010
    Las Vegas
    Quote Originally Posted by Marcy View Post
    While I agree with most of what you're saying I have to disagree with "listen to the engine, it's a good habit to get in to". Many, many people that shifted their v-twins by listening to the engine were lugging the crap out of it, if you are just learning about your Spyder you should check your tach and shift at the suggested points. Then once your ear is trained to the sound at the correct rpm you can shift by the sound of it.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default COMMON SENSE SHIFTING
    Ahhhhhhh now this is something I can agree with .......... I generally have my RT in Eco mode .... I pay NO attention to the Green arrow ...... When I'm in the twistie's and cranking it .... I turn it off .......... It's probably saving me some gas 3/4 of the time .................... jmho ...... Mike
    Default Gotta say...
    Ever since they put the eco mode in (to apease the epa) it has shown very little savings in gas consumption. Some of the original testers found at best you could save 1 mpg but kill the fun of the machine.. want great gas mileage get a moped... best eco friendly unit around..pedal till engine starts and when your out of gas....
    It will allow you to shift a bit earlier, and it limits and slows the throttle response...
    But the Green Arrow might be considered a dangerous feature, as it diverts your attention from the road in front of you.
    I used if for a tankful of fuel once, and the savings was minuscule...
    Jun 2012
    Fairmont, Minnesota
    I hate it. I have only used it a few times but the loss in performance is significant and if I use their shift points, I lose mileage. My last tank using ECO was a bit over 32 MPG. My last tank without ECO was over 39 MPG. My normal mileage without ECO is about 37 MPG.
    Mar 2017
    Star, Idaho
    I tried using it, I noticed when I took off on first it would sometimes go up into the 4000s RPM before arrow came on, after that it would tell me to shift at low 3000s. I also noticed sometimes it would tell me to shift without increasing speed or RPMs. I found myself concentrating on how often it was off than paying attention to more important things. Much happier not using it.
    May 2016
    Mansfield, Ohio
    Interesting... Our 2015 ST Limited doesn't have this feature and we are considering moving up to a new RT. So I downloaded the 188 page user manual for the 2021 RT Limited and searched on "ECO mode". It appeared in one location (pg 31) that shows how to turn it ON and OFF. Absolutely no other explanation of what it does!! Most likely the best evidence that it's pretty useless.
    2021 RT Limited , Deep Marsala Metallic (red)
    Apr 2021
    Ky
    This thread is 4 years old, wife got her F3s and doesn't experience difficulty passing in eco mode.
    As others said ignore the dash and go by sounds and feel.
    Nov 2020
    Lincoln, Nebraska
    Tried it once, couldn’t drive it like I stole it.
    Sep 2020
    MO
    Useless, they could have better spent money manufacturing mirrors locks, decent adjustable handlebars, garage door openers, etc. etc.....
    Northern Kalifornia
    Like BK911, I run Eco mode 90% of the time. I shift by sound and feel not by the green arrow. When I want to pass somebody I hit Eco Boost and away we go! Finding the sweet spot to shift all depends on how far you've twisted your wrist.
