Results 1 to 13 of 13
    Apr 2017
    So Calif.
    Default 2014 RT Limited Steering slack
    Hello,
    My wife, as of 4/26/17 is the proud owner of a 2014 RT Limited. So we both joined Spyderlovers.com.
    She bought it from a good friend and we are proud to own it.
    We are planning on taking it down to get it completely serviced so we know it is in tip top shape.
    I have a question.
    I noticed the steering seems to have some slack in it. When it is parked, the handlebars will move back and forth as if they are loose.
    Does this look right? See video below.
    Thanks for your advice
    Ron
    http://vid281.photobucket.com/albums...psthmcw4y6.mp4
    Nov 2015
    Myerstown, Pennsylvania
    & How many miles are on it? Warranty? If this was my spyder I would be trying to look at the input shaft of the steering unit while moving the handlebars to find where the problem is. If you have a warranty then find a dealer with a good service department & let them handle it. Good Luck!
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Sep 2014
    USA
    Its normal- relax and ride the SPYDER
    Nov 2015
    I'll have to check mine. I've never noticed it before. Thanks.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Apr 2017
    So Calif.
    Quote Originally Posted by SteveLaoyster View Post
    The bike has about 12,000 miles on it. I am just hoping it is safe to ride!
    Default Interesting. ...
    Welcome to the spyder world and this site. As I see the video seems you will be alright ryding but make mention to the shop about it. Don't ryde that model and may be normal for it. congrats on the new ryde...
    Sep 2014
    USA
    You will notice it more when the bike is not running. Its been like that since day one on mine and have had no steering issues yet.. Others have commented on this topic on other threads.
    Sep 2016
    Parma, Idaho
    Default RT Steering
    Just thought I'd add my three cents (additional penny added for inflation). I have a 2012 Can Am Spyder RT-SE5. When the bike is simply sitting, there is a fraction of free play with the handlebar. I asked my own dealership about it, as I'd not experienced such play on any of the Gold Wings or Harleys. I was told by the dealer's service manager that this was normal for the Spyder. Now with just over 23,000 miles.
    United States
    You should have that checked out. Our 2014 RT had some play in the steering and I was thinking the DPS unit since the tie rods were all tight. Took it to the dealer and found that the steering nut had loosened slightly. Don't take it for granted that it is normal. have it checked out.
    And.....
    on the new ryde. We are closely approaching 40k on ours and having a blast.
    Active Member TexAmRider's Avatar
    Jul 2013
    Coahoma, Texas
    Default Its Normal
    All three of my RT's have had the play in them while sitting still. Have no noticeable issue with steering. Once aligned, rides on a rail.
    2016 RTS Special Triple Black, BRP Freedom Trailer, Spyder Pops Rear Lighting Kit, Spyder Pops Full view Turn Signals, Trunk Light, Rivco Highway Pegs. Doc's Spring Tensioners, Trunk Organizer, Magic Mirrors, Foam Grips, back to Stock Windsheild, Lamonsters cat delete, Bajaron sway bar, More Farkles to come !!
    Mention it to the dealer. And, on your new purchase.
    May 2013
    Stanton, ca
    I have commented on this a few times. I helped BRP do demo rides at dealers last year and rode several new RTs.
    I noticed that all the 2014 and 2015 RT's I rode had a lot more play in the steering than my 2011 RT does.
    Obviously some change was made in 2014?
    Bob
    Sep 2014
    USA
    U Joint play..That what most of us are feeling.
