Results 1 to 9 of 9
    May 2013
    Apex, N.C.
    Default Question about trailer hitch
    I understand that the show chrome hitch will work for the RT, ST, RS, and GS. I know that the F3 looks totally different, but the swing arm on the F3T looks more similar to the previously mentioned bikes. So, will a hitch from a RT fit a F3T?
    Jul 2011
    Mitchell, Ontario, Canada
    Yes it will fit. The swing arm is the same.
    Very Active Member vtrider's Avatar
    Jul 2008
    Cambridge, Vermont
    The BRP hitch that I took off my 2013 RT LTD fits onto my F3T. As stated above the swing arm is the same. I just need to get that wiring harness set up for my RT622 trailer.
    Jul 2011
    Quote Originally Posted by vtrider View Post
    The wiring harness harness from the RT will fit the F3 too. Did you take it off?
    Bryant, Arkansas
    I could be wrong on this but i believe that the wiring harness for the RT and the F3 are different, the Hitch is the same.
    Cruzr Joe
    May 2013
    Apex, N.C.
    Thanks guys. I don't have a wiring harness on the RT, as I just use the hitch to attach my Doc Humphries rack. Thanks again.
    Jul 2011
    Cruzr Joe
    OK I will bite. What's the difference? Same 10 pin connector with the same pinout.
    RT, ST and F3T are all the same.
    Here is a picture of the connector to tap into from the F3 hitch instructions.
    Here is the picture of the connector from the RT hitch instructions.
    They used the same picture.
    Bryant, Arkansas
    I was relying on info from Lamonster Garage which says that they are different wiring harnesses and are not interchangeable.
    Cruzr Joe
    Jul 2011
    Cruzr Joe
    BRP harness will work. Show Chrome harness for RT will not. Other after market may not as well.
