Re: makes getting air into the rear tire - so easy.
Last week I used my newly-purchased Lamonster-Approved Air Pack. It took a minute or two or three to get it on the rear tire valve. But that Lamonster-Approved device is one sweet way to inflate tires. I'm sticking with it.
Jerry Baumchen
PS) One thing I don't care for with the Air Pack is that it is easy to change the values; from PSI to Atmospheres, etc. Once I learned to keep my fingers off of 'that' switch, it was easy to understand & use.
Jerry Baumchen
I like that. Will see if he has some at Spyderfest.
David
It's a pretty sweet rig!
(It even works well on that pesky rear tire valve...)
Jerry Baumchen
The Lamonster device is super easy on the rear tire, especially if the valve stem is in the right spot. Jerry my first time on the RT took some finagling, but the second time was seconds. The F3 is a piece of cake. Love this device!
David
Why wait. You can have it in two days.
It is a very nice piece and works as advertised. However, I can't seem to un-screw the cap from the valve stem before a couple of pounds of air is lost. I guess I'm not very fast. It needs a clamp on piece instead of a screw on IMHO.
What's the secret? Is there a fitting that would screw on the end of the little tube that converts it to a straight clamp on.
I don't know how to stop that air loss; it was my biggest worry as well...
Perhaps some practice with will help!
(Or a pair of "handier" hands! )
I found that the air loss was less than a pound, so I just set the unit to one pound more than I had planned.
Stan
The kit now comes with a 90 degree clamp-on and a straight screw-on. The 90 won't work on the rear. You can add more air to compensate for what you lose or just get better at it.
I just purchased the Lamoster air pump. It came with 2 hoses but I have yet to figure out a way to get that short hose to the rear tire on my F3. I also cannot figure out how to tell how charge the devices is.
Harley has a short air hose extension for use with their Electra Glide Ultras. Put that on the Lamonster compressor and then use that to connect to the valve on the Spyder and you wont lose any air.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
