Hey Dummy, your turn signal's on
So, what have folks done to remind them that their turn signal is on?. I see a lot of people add the signals to the mirrors, I did that too, but I can't see them. Have people added anything to the dash or anything else to the mirrors or anywhere else? I'm pondering just buying a couple small individual LED's and wiring them in....
Ideas please..
I did...
I added a small green led light on each side of the dash that has been very effective. Simply wire them into the turn signals and your good to go...
Remember, if you forget to turn them off, they automatically cancel in 20 seconds.
Well heck, I didn't know that....thanks
Many owners, including myself, have installed LED turn signal lights on the outside of their rear view mirrors. Even though they self cancel, it's one more thing to spend money on.
Yup, did it...but they are too far forward that I can't see them when I'm driving.
I wish. I believe it's actually more like 30 seconds, longer than I wish they were. I think that's about twice as long as the Goldwing cancel time. It was a little bit short.
I have mine on the outside end of the mirror. They are fairly visible but I still miss noticing the signal. I think one of the best solutions I've seen mentioned is a red or green LED behind the speaker grills. The dark region near the speaker makes them easy to see, at least according to the photos I've seen posted here.
WELLLLLLL NOW THAT YOU MENTION IT
IMHO - those LED's would have to be extremely bright to be seen in the daytime (the ones inside the speaker grills ) .....I did this but it only worked at night, and my led's were pretty bright ....... Mike
My TricLed mirror signals show up extremely well during the daytime. They're mounted on the inside frame edge, next to the glass, in direct line of sight of the driver.
CAVEAT: These LEDs are uni-directional only; they shine brightly to only one side of the (flat) wire. If they inadvertently get mounted backwards, with the bright side turned INWARD toward the mirror body (mine did) then yes, they are only faintly visible, useless in fact, in the daytime. Mine were first mounted along the top, and the solution was to pry them loose, rotate them 90 degrees downward and reglue them "bright-side out." The instructions do not tell you this, so beware!
This is on the RT mirrors, of course. I dunno about those little "hand mirrors" way forward on the RS, etc.
NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
Retained the old mirrors with TricLed Signals
General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
Riken Raptor HR.........rear tire (at 114,200 miles)
Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
Gear Brake Decelerometer Module
OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
BajaRon Anti-sway Bar
Kumho ECSTA AST rear tire (at 14,200 miles)
TricLed Turn Signals in Mirrors
That's true if you make a sharp-enough turn, like at a corner. But if you signal a lane change or a interstate exit - any kind of gentle turn - you'll have to manually cancel the signal.
I have the TricLED strips on the outside of my mirrors, and they really help me. Sometimes when I cancel the signal, I accidentally push it the other way. The LEDs help me notice that.
This has been a gripe of mine since day one. I cant see the green blinky thingy when I'm riding during daylight hours. Dunno if I wanna splice into the turn signal wires and mount an extra idiot "reminder" light or just press that stupid tiny turn signal switch and hope for the best. Considering there is also the option of mounting a tiny reflective element just above each turn signal I will probably never splice into my wiring harness. My thoughts.
I did this as well.
2008 GS SM5, Full Moon Silver
2007 Piaggio MP3 - 250cc
My right turn signal sticks in the "on" position. I got use to turning it off after every turn but I also installed turn signal LED lights on my mirrors which serve as a reminder they are on.
This is what I did to mine.
Could not tell when I bought them, but I wish they had been brighter.
Bingo!!!, it's usually the lane changes that I do this same thing.....press it too far, or not straight in to cancel
Found some LEDs on SuperBrightLeds I thought I'd try. Ordered two for the "reminders" and a few extra for some accent lighting.
If you're still under warranty have it replaced. I did on the 2013 RT I had because it also stuck in the right 'on' position.
They will self cancel, but like I say above, it takes about 30 seconds to do so. At 60 mph on the highway that's a half mile they're blinking away aimlessly!
Not true on my Spyder. I tested mine and if I fail to turn off after a lane change they will in fact go off on their own, but it seems to be a very long time.
