Does FOBO equal new tire balancing?
Seems like a worthy add on but I wonder if I need to rebalance the tires?
2017 F3 Limited
Don't know. ..!!
Don't know any one that has checked if you need to..but most don't...how much does the unit weigh..?
FOBO DEVICE
from personal experience, No
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Each one weighs ounces (if that)
Chris
2016 F3-T SE6
FOBO WEIGHT
Grams , if it was in ounces, tire would have to re-balanced ................ Mike
Use dynamic balancing with beads or Ride-On and you won't have to worry.
I doubt they will throw things off.
A rider on the FJR1300 forum weighed them at 7 grams each.
A quarter of an ounce.
Chris
2016 F3-T SE6
[QUOTE=Firefly;1232716]Use dynamic balancing with beads or Ride-On and you won't have to worry.
Would using this stuff damage the FOBO? I'm sure that using green slime would not be good for the FOBO.
From my experience no rebalance required.
Ozzie Ozzie Ozzie
I had mine checked when I got new rear tire on my 2015 Rt on problem.
