Results 1 to 14 of 14
    Sep 2014
    Grand Junction, Co.
    Default F3T Panel Removal
    I'm breaking down TxSpyderGirl's new F3T to add some power plugs and
    am stuck. I know the F3 is put together like a Lego toy, but I'm hesitant to
    pull on this without knowing what's underneath.
    Has anybody gone this far on an F3T yet? If so, is this just "snapped" in.
    p.s. - am I the only one that thinks Can Am must buy yellow lock tight by the tanker car....
    Pensacola FL
    It does come off, pull slightly towards the rear of the bike. There is a small plastic lip that holds it in place. Scared me to death as I was pulling on it. Thought I was going to break it.
    Sep 2014
    Grand Junction, Co.
    Quote Originally Posted by Moosemanj View Post
    When you say "little plastic lip" do you mean a "snap" lip, or a slide lip.
    I'll pull towards the back of the bike nonetheless.
    Thanks for the tip.
    The F3 is much easier to work on than her RT, but Can Am still has a ways to go on design and engineering.
    Pensacola FL
    Slide lip. I agree, I have both an RT and F3
    Jun 2015
    Midland, TX
    Pull the front of the piece a little out away from the bike and then pull up hard on the back....it takes a good tug.
    Sep 2014
    Grand Junction, Co.
    Quote Originally Posted by KJWEB View Post
    I can't tell you how much I dislike doing that. Plastic snap tabs shouldn't be used to secure motor vehicle parts.
    Central Ohio
    Before you yank that back tab loose, put some masking tape around the area to help prevent scratching the paint when it pops off.
    H2O
    Jun 2015
    Midland, TX
    Quote Originally Posted by TexasMule View Post
    Yes sir, I agree. But once you have it off, you see how the tab fits in the slot.
    Harrington, Australia
    It does make a heck of a noise when you pop it off. I've done it a few times, and still feel nervous doing it, even though it's a pretty tough piece. It does take some force.
    HeliBars Handlebars
    Kenda Kanine rear.
    Nov 2016
    Hummelstown.Pa.
    Can you post a pic of it when you have it off? I'm curious also to see it
    Sep 2014
    Grand Junction, Co.
    Quote Originally Posted by SpyderF3 View Post
    You read my mind.
    I was going to do just that.
    Sep 2014
    Grand Junction, Co.
    OK, got the right side off, and didn't totally mung up the tab. I need to epoxy the tab to strengthen it,
    but it's still on.
    I thought I saw grade school engineering on the RT, but this piece of work takes the cake.
    Here's the slot the tab goes in - sideways.
    and here's the tab that slides in the slot and clicks in.
    What kind of mentally challenged designer makes a tab that you can't get to, and you
    have to depress to release. Totally insane. I'm assuming Can Am dealers have a special
    tool that can reach up and unlatch the tab.
    Under no circumstances PULL UP on the rear of the piece, you will break off the tab.
    You need to try to ROTATE IT OUT away from the bike.
    This should be in the Dumbest Designs Hall of Fame.
    Jul 2010
    Las Vegas, NV
    Unhappy LOL
    Mildly retarded engineers, of course! That's what kind of engineers design works of art like these! Mouth breathing morons! These tabs, the mirrors, the air valve on the rear wheel, the coolant bottle cap, the 990 air cleaner, the oil filter for the transmission that dribbles oil everywhere, the suck azz drain plug design, the windshield arm........
    a comedy of errors! The latest touch of brilliance? Wheels Powdercoated so poorly the coating flakes off and glues the wheel to the hub! Thank you for exporting work to me! I unscrew these gems every week! For the price point of these machines, they should be world class. In every case, every part. I love these things, and the freedom to ride they allow. Step up!
    Joe Meyer
    Sep 2014
    Grand Junction, Co.
    Quote Originally Posted by cptjam View Post
    Don't want to get into a lengthy discussion with you Capt about form vs. function, but I've worked on motor vehicles for almost 50 years, and if you
    have to work on these bikes on a daily basis, you have my sympathy.
    For a vehicle approaching $30K, not to have a bluetooth radio is a crime. My budget truck has bluetooth radio, heated seats, air bags, reverse camera, auto dimming mirrors, etc.
    and it didn't cost as much as this F3. The GPM on these bikes must be phenomenal, but the same can be said for most bikes.
    Got both sides off, now that I know how they come off, I probably won't have to remove them for a while.
