WikiSpyder.com is up.....
Roger has it up and some have been able to register...bit bumpy but almost there...
wikiSpyder might be ready.
Let's just see what happens.
I believe that the Login problem is fixed.
Okay, if you feel brave and you want to try to generate some content into wikiSpyder you may as well try.
The first thing you will need to do is register. That can be found either by scrolling all the way on the left hand panel (if you are accessing from a larger device or under the three bar menu if you are using a mobile device.
This is sort of like beta testing, but I am hopeful.
Any questions just ask.
www.wikispyder.com
I was able to get in and post about my install of the Idler Pulley on our new 2016 F3 Limited.http://wikispyder.com/
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
I have trouble registering.
I entered my username PrairieSpyder and my email. It asked for a pw and I gave one. Didn't like it. Then I tried with my email address and that email pw. Didn't like it. I also tried my WordPress ID & pw. No go.
I'll wait to see if I get an email confirming my registration.
I just registered and logged in with out any problems. Just poked around a bit. This should be a great resource!
Bogie
