Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
  1. #26
    Nov 2014
    TriCities, WA
    I just replaced mine with a Walmart Shorty one, $4, tried to get the BRP one off, no way, Kevin had the solution, bust it off and use a 7mm socket to get the "screw thing out".
  2. #27
    Dec 2016
    Port Richey, FL
    Quote Originally Posted by pitzerwm View Post
    Did you have to replace the base or just screw the new antenna into the factory installed base? I'll spend a few bucks for a shorty IF it doesn't turn into a major project.
  3. #28
    May 2013
    Indiana
    Quote Originally Posted by nakerr View Post
    Makes me fondly remember the old GL-1500 antennas that folded down forward and fit easily under covers.
    GL-1800s had the same folding antennas/
    2021 Marsala Red Metallic RT Limited
  4. #29
    That's not possible with the Spyders, due to the angled mounting surface...
  5. #30
    Knoxville, TN
    Default antenna
    most covers are nylon, just mark where the antenna would go through and use either a cigarette or soldering iron to melt a small hole through the nylon to allow the anternna to come through the cover. if you use the soldering iron, it will melt the nylon and create a solid ring around the hole so it doesn't tear.
    Ravseren
  6. #31
    Vermont
    Quote Originally Posted by Czardobbs View Post
    The antena is extremely tight; too tight to turn by hand... Any idea what size wrench to use?
    Use a 7 MM deep socket wrench. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  7. #32
    Vermont
    I think it is a 7 mm. I have a cheap wrench that I heated and bent to fit into the opening.
    yes, it is a 7mm deep socket wrench. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  8. #33
    lake mary fl.
    7mm deep socket should do it! Slide the socket down from the top of the antenna, then use a pair of pliers on the socket! That's what i used!
  9. #34
    Sep 2020
    ID
    Default Oldguy
    Quote Originally Posted by garageguy View Post
    I agree, I replaced the $50 (PoS ) BRP breakable mast with the shorty flexible $9 WalMart antenna which will flex when you put the cover on and reception is equal. Coming from the mtns. of VA.
    The Scosche RMA900 Replacement Car Antenna from Walmart is what I settled for.
  10. #35
    Durham,Maine
    Quote Originally Posted by 2cmyhre View Post
    2012 RTL , Pearl
Tags for this Thread
