Results 1 to 21 of 21
    Feb 2016
    HAWTHORNE nj
    Default tinting a shield
    Hi guys another one of my many questions. can a shield be tinted.
    Default Not sure...
    We talking wind or helmet. Easier to get tinted helmet shields but on the wind shield being some type of plastic I don'the know. Could check those films and if they can be applied theyou plastic. I just wear sunglasses... never had a windshield I could look thru...
    Default TINTING
    If you are talking about a windshield ....... I think you could use the same stuff that they use for cars and this might be removable if you don't like it...... but consider this ..... At night I think it's going to cause a problem, and if it does you might hit a STUPID pedestrian , because some think they are in some kind of protective shield and can't be killed ...... To find out if you like it drive at night with SUN Glasses on first ........ But be very careful .........Mike
    Sep 2014
    USA
    sure you can put that window tint on, not sure why but yes you can
    Don't we have some aftermarket suppliers in here, that already sell tinted versions?
    You could switch back and forth; should that need arise...
    May 2013
    Apex, N.C.
    I cut my stock windshield down by 7" and wanted a tinted shield. I tried the film tint first, and yes, with the curve in the shield, it was nearly impossible for a newbie like me. Next I tried the spray on tint. First I tried it on a plastic water bottle for a trial run. It worked great. After cleaning the windshield, I did a coat on it. It was terrible. I decided to do a couple of layers, and after a while, it looked great, but it was too dark to see through. Since the shield was shortened, it was fine in the low position. But when I would raise it for interstate driving, I could see over it, but now very clear on the things right in front, and close up to the spyder. Eventually I took it off and replaced it with a +4 wide, -4 high, vented shield. Here is a picture of the cut/tinted shield. And another of the one that I use now.
    Jun 2012
    Fairmont, Minnesota
    Might a tinted windshield be against the law on a machine where you need to look through it to drive and see the road?
    May 2013
    Apex, N.C.
    Quote Originally Posted by rcturner View Post
    I think that would depend on the darkness of the tint, and height of the windshield. For the one that I tinted myself, you would be looking over it, so it was not a problem. For the tinted/Vented one that I have, it is a very light tint, and you can easily see through it.
    Feb 2016
    HAWTHORNE nj
    Default tint
    I want a light tint and I have had tint on all my bike wind shields in the past. Ill take a look at some of the companies mentioned . I like the way tint shields look on this bike. plus with my height I look over the shield and its a 26inch stock unit.
    Central Valley, Ca
    Where did you end up finding the wrap to tint your windshield? Do we have any service vendors on this site? I did like the one on this one:http://www.spyderlovers.com/forums/s...highlight=tint
    May 2013
    Apex, N.C.
    Quote Originally Posted by ussoldier View Post
    The one in the first photo is spray on tint that I picked up from Advanced Auto. The second one was purchased tinted from the start. I got this one off ebay, but I think it is also sold by F4.
    Feb 2016
    HAWTHORNE nj
    Default very nice
    that bottom one is the way I want to go. I don't want to spend 4 bucks for another shield.
    Central Valley, Ca
    So the spray would be better than? I have a Route 129 windshield, and I would prefer to tint it; since, I look over it. What is the spray called?
    Linden, CA
    Yes just like your car windows
    Quote Originally Posted by MOSESS View Post
    Central Valley, Ca
    The problem is that my window is made out of some polyca.... plastic not glass. So a car window that cannot be tinted due to heat. What spray for tinting would that be? I know it can be black spray can.
    May 2013
    Apex, N.C.
    The stuff that I used came from Advanced Auto and was called VHT Nite-Shades by Specialty Products. I must warn you that it had to be sprayed on in layers (about 3-4) because the finish was not that great on the first coat. After a while, it looked great, but you cannot see through it at all after the 3-4 coats. I did this on the rear side. Only attempt this if you don't need to look through it at all.
    Central Valley, Ca
    I am curious now...the second image is that with 3 coats and the first is 6 coats? What do you use clean the windshield? Did you use thinner or dish washing soap before you sprayed? I saw Lamonster but he did a perforated wrap...which was really nice. But, I'll spray it; since it is cheaper.
    May 2013
    Apex, N.C.
    Those are actually 2 different windshields. The lightly tinted one with the vent is a factory tinted shield. The darker one (almost black), is the stock shield that I cut down by 7" and applied 4-5 coats of spray on tint. There is no way to see through it at all. With a high intensity flashlight shining on the back side, you can barely see any light going through it. As for cleaning, I just use typical glass cleaner on the exterior, since the inside is where the tint is sprayed.
    SpyderLovers Sponsor
    Nov 2012
    Twinsburg, Ohio
    Default Tinted windshields
    F4 offers a tinted windshield for the Spyder and it is made from our high optic polycarbonate tinted material. It has the same scratch resistance and rain shedding that all of our shields have. Give us a call at 330-968-4644 and we would love to earn your business.
    Don Frank
    Here is a video for the RT that will show you the tint also and the various heights.
    Central Valley, Ca
    Quote Originally Posted by F4 Customs View Post
    Don Frank
    Thanks, but I prefer to look over it. Plus, I am not willing to pay extra cash for another windshield. I made contact with my local law enforcement regarding tinting windshield. I was told that I am not allowed to tint a windshield; however, I am able to tint the "wind deflector".
    lake mary fl.
    Back when i was in chicago i tried to get the windshield tinted! Only to be rejected by 2 professional shops, that said, it can be done, but eventually will bubble up because the windshield is made out of plastic! Cars have a glass windshield and that's what the film is made for! Good luck with your project!
