REAR TIRE REPLACEMENT
I am needing to replace my rear tire and I have seen post before with suggestions on this. What is the best tire and did you reinstall the tire on your bike . If you have advice, experience or comments I would appreciate you sharing them with me. Thanks Cagey
Cagey,
A very popular replacement is the Yokohama 205/50/15. I believe that will be my next one.
I have the same size Kuhmo on mine. Balanced and installed by local dealer. Cost was 125.00 and worth it since I do not have a place to work on the bike.
Good luck,
Bob W.
2015 RT Ltd SE6
Intense Red
BaJa Ron Torsion Bar
BaJa Ron Shock Adjusters
Premium Driver Seat Back Rest
Diamond R Spyder Armrests and cup holders
Wheel Aligment Squared Away
Trailer Hitch Value Accessories
Harbor Freight trailer black
Stebel Nautilus Compact Mini Black
139 decibel air horn
Garmin GPS
The preferred Yokohama S-Drive is actually the 205/55 - 15 as its a near perfect match to the physical size of the OEM tire as well as a much better construction tire. Great handling, perfect balance, long wear and great traction from a real performance tire. We sell and install quite a few of them.
The best rear tire I have run so far is the Michelin Premier A/S in 205/60R-15 size. Great handling and Fantastic in the rain/wet roads. I have around 14,000 on it and stills looks good and still fantastic in the rain.
I purchased it at Costco and took the wheel into them. They dismounted the old tire and installed new valve stem and tire for $15.00. Since I run Ride-On in my tires I declined balancing.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
REAR TIRE
The first thing you need to know is ....who is going to do the WORK !!! .... If you use a Dealer make sure you know beforehand if the dealer will mount a tire other than a KENDA , because some won't ....... The Michelin Premier is an excellent choice as well as The General Altimax RT 43 in 215/60-15 selling for about $ 80.00 on Amazon & E-bay with free shipping.................Mike
R&R
I'M ON MY 5th KUMHO, 3 ON MY RS, AND THE 2nd ON MY F3, AND I CAN'T SAY ENOUGH 'GOOD' ABOUT THIS TIRE... HOWEVER, THESE KUMHO'S ARE GETTING VERY RARE SINCE THEY'VE BEEN DISCONTINUED....
I JUST PURCHASED A MICHILEN HYDROEDGE 215/60R15 AND IT WILL BE REPLACING THE KUMHO OUT BACK....
NOTE: MY WIFE HAS THE MICHILEN HYDROEDGE 215/60R15's ON HER CAMRY, AND THEY ARE SUPERB IN EVERY WAY... NOT TO SAY THAT THE SPYD3R & CAMRY HAVE ANY COMPARISON, BUT IT GIVE ME A BIT OF COMFORT....
DAN P
SPYD3R
23,000 on the Michelin on the rear of our RT, lots of tread left. Many options in the 215/60/15 size and it corrects the speedo error.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Yikes...!!
I think this site has made choosing a tire a real task. If you search you will see...and maybe in time find one. See above and pick at random...
