Results 1 to 10 of 10
    Bryant, Arkansas
    Default Did You Know ........
    Things i learned and wanted to pass on......
    1) The Wheels & Tires from a BRP RT-622 Trailer are interchangeable with the BRP Freedom Trailer.
    2) A 13/16 Thin Walled Spark Plug Socket will fit the lugnuts of the Spyder and the BRP trailers.
    3) The recommended Torque on the front wheels of a spyder is 78 - 80 Lbs.
    4) The first thing BRP Roadside Assistance will ask you for is your Spyder Serial (VIN) Number, and then your Lic Plate # and State that issued it.
    5) Only use DOT 4 Brake Fluid.
    6) When disconnecting your Battery always remove the BLACK (-) cable first and replace it last.
    7) Premium Fuel is recommended for your Spyder.
    8) If your brakes make your Spyder Wander when heavily braking, try this, loosen both front tires and re torque them to between 78 & 80 foot lbs.
    9) let your oil get up to normal operating temperature (15 minute ride) before you check it.
    10) There are spare blade fuses in the fuse box covers.
    11) If you leave your raingear at home ................ It will rain.
    That's all i know that i wanted to pass on.
    Cruzr Joe
    Aug 2015
    Canton, Ohio
    A genius compilation of possibly disputable content, except for number 11!
    Joe
    A great Tuesday PM read. As usual, thanks Joe.
    Joe knows...
    He's even got the shirt to prove it!
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Thanks!!
    Thanks Joe!!
    2014 RTS , Circuit Yellow
    Default Thanks....
    All good points to remember...
    May 2013
    Edmonton Alberta, Canada
    Words of wisdom, thank your wife for me Joe!
    2014 RT-Ltd , Cognac
    Invalid Emails
    Rotonda West,FL
    Good Read
    Thank You Joe!
    Mar 2012
    Florida Space Coast
    Sounds good to me!
    Oct 2014
    Fort Mill, SC
    Cool stuff.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
