Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 85
  1. #26
    Apr 2011
    GREENVILLE, SC
    Default 1800
    1800 cc or MORE.....
    i was blown-away with the Daytona model.... DAYTONA signifies POWER, and the engine isn't any different than any other 1330....
    bore it out to 1800cc's or more... put a turbo or super-charger on it... DO SOMETHING BRP... you lost it for 2017, don't let that happen for the 2018 models....
    bon jour
    Dan P
    Easley, SC
    SPYD3R
  2. #27
    Bryant, Arkansas
    You heard it here first ................... don't forget ...........................
    2018 F3 will be a leaning reverse trike.
    Cruzr Joe
  3. #28
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    BRP - are you listening? At least some of these ideas should make IMHO.b b
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
  4. #29
    Aug 2015
    central oregon
    How about a proper frame mounted trailer hitch. The current one is a joke.
  5. #30
    Aug 2008
    MA & NH
    That just means that it's time to trade-up! (Again!)
    Can't do that for quite a while. (Of couse I've said that before)
  6. #31
    Jul 2010
    Las Vegas, NV
    Default Power
    Two up, pulling a trailer, on a trip; needs more power! 20% to start, easily accomplished.
    Make the RT longer in the middle; longer saddle, more room. Bigger saddlebags. These do not lean: bags could go almost to the ground, and wider. Top box could grow aft. Add u fit capability to all models. Make LED headlights stock. I could go on and on, but start here!
    Joe Meyer
  7. #32
    Panama City Beach, FL
    Cruzr Joe
    I see granite in your future
  8. #33
    Nov 2015
    SC
    Default Noise
    Do something to cut down on all the noise from the engine. A 20 year old gold wing is silent in comparison to the 1330.
  9. #34
    Aug 2015
    Canton, Ohio
    Quote Originally Posted by Windagetray View Post
    ....the trivial stuff listed just to see better reliability in the stuff my 2014 RT-S already has.
    1- Rear tires that last as long at the fronts
    2-Get the quirks out of the existing computer software
    3- Upgrade the compressors and figure out how to keep stones from sitting under and rubbing through the air bags
    4- Keep stones out of the belt (or go to shaft drive!)
    5-Increase the frame strength so they don't crack. I've seen at least one posting on here about that and heard first hand of another.
    6-Upgrade front suspension so the frunk bottom is not hitting the road constantly without installing aftermarket items.
    7-Increase dealer presence so we don't have to drive 50+ miles for needed services
    8- Make the $30K machine WORTH $30K!
    Sir, if you don't mind me asking, why do you even own one?
    you make a big deal about frames cracking yet you only heard of it happening twice.
    the rear tires, for gosh sakes new auto tires don't last as long as replacements either, my friends on other brands replace theirs too.
    Dealer network, unless you have been on that side you have no idea how difficult that is.
    You purchased a complex mechanical system, they all have issues. If you have these problems and purchased one then you did not do your homework or ignored the obvious.
    this post was constructive until YOU decided to start the negativity.
    Life is too short to be this miserable, sell yours and move on to something else, it would be good for you.
    Joe
  10. #35
    Aug 2016
    North Carolina
    Default My wish list
    First, I have no intentions of purchasing another Can Am, at least not until I get 10,000 or more miles on the one I have. But, the original list....
    1. Bluetooth - phone to stereo. Control of phone music from handlebar controls. (Easily handled by doing a Garmin 595LM, Sena 10S).
    2. Enhanced stereo playback control from handlebars. Currently if you select a new playlist it will only play in order of artists. A "Random" option would be nice. (As per No. 1)
    3. Backlit controls for high beam/low beam switch. NICE IDEA
    4. Crisp feedback for turn signal and cruise control switches. They're mushy. It's easy to set a turn signal when you try to cancel one. YUP
    5. Fix the clock. The clock runs fast on almost ALL Spyders. ????
    6. Fob instead of keys like Harley and Indian. FOR SURE, BUT AT WHAT COST?
    7. Stiffer sway bar so we won't all be replacing ours. NOT CERTAIN THIS IS GOOD. BY ALTERING THE FRONT, ONE CHANGES THE GRIP F/R, POTENTIALLY CREATING A LOOSE CONDITION
    8. Built-in belt stabilization so we won't have the vibration at 65-75 mps. YEAH, THIS IS ONE TO GET THROUGH
    9. Built-in TPMS - it would be nice to have a display on the dash or GPS (Garmin has that option on some models). MORE MONEY
    10. Brighter turn-signal indicator on dashboard. The current one is only useful at night. OR LARGER
    11. Better grips. Stock Spyder grips and skinny and feel like bicycle grips to me. AGAIN, NOT CERTAIN I NEED THIS
    12. A better rear-wheel air valve position so that you don't have to have 10 inch fingers with 8 joints to get to the valve stem. GOSH, I NEVER COUNTED
    There are some changes I would suggest as well.
    1) Built in GPS option....speedo and tach could be on same side, GPS on other
    2) Option of changing the digital dash so as to have the RPM large like the speed, or in place of the speed.
    3) Option of having the heat from radiators come up onto rider.
    4) Race exhaust option....a typical race exhaust is a short glass packed straight through system. Like I haver on mine now.
    http://www.spyderlovers.com/forums/s...-Exhaust-on-F3
    5) Adjustable windshield
    That is my thinking at this moment...subject to change at anytime....
  11. #36
    Sep 2014
    United States
    Quote Originally Posted by Buckeye Bleau View Post
    Joe
    I know you didn't direct this to me, but my purpose in this annual list is just to put our ideas forward for BRP to see. Many aren't affordable or practical, others would be easy to implement (good switches with mechanical feedback shouldn't cost more than mushy switches).
    I share the fear that some of these items (longer, wider, more powerful) would change the nature of the beast and send prices upwards, but it's still a good exercise to document potential improvements. I am curious about the price of these things - if Kia can build a vehicle with 4 cylinders, A/C and 4 doors for $22k then some of these changes shouldn't send prices of an RT to $35k.
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
  12. #37
    ...Life is too short to be this miserable, sell yours and move on to something else, it would be good for you.
    Joe
    I've got to say:
  13. #38
    Dec 2014
    Central, Florida
    My vibration is right at 77mph but gone at 79mph. The list is great. I'd like like to add better gas mileage & a smoother, more powerful & efficient running engine. Perhaps an electronically control throttle as well.
    Sent from my SM-G935P using Tapatalk
  14. #39
    Dec 2014
    Central, Florida
    Oh just remebered, heated seat, dash mounted power outlet,
  15. #40
    Apr 2016
    Tennessee
    Quote Originally Posted by modagwood View Post
    Has anyone installed the brp belt tensioner on an RT.using Doc Humphrey's after market parts to make it work. Thank you.
    I have mine ordered...will advise once installed !
  16. #41
    Dec 2014
    Central, Florida
    [QUOTE=arecibo50;1203383]Oh just remembered, heated seats w/hi low seperate controls for passenger & rider, better heated grips for the passenger, dash mounted power outlets, exterior power outlets for the pssenger, built in highway pegs, Bluetooth helmet capabilities for both passnger & rider tied intothe GPS & or sound system & intercom. These could be options as not everyone may want or need these. For me this is an exercise of wanting what I previously had & liked on other owned machines. Price is important but the way I look at it is if I like it & I want it I'll go for it & if I add up the cost of buying & installing many aftermarket products it probably comes very close to having the factory install them. I guess you could loose some of the uniqueness of individually farkling up the ride if many of these are factory installed but that's up to the individual & besides I'm sure one can always find something different to add to the individual look they may seek.
  17. #42
    Port NEches, TX
    Quote Originally Posted by mmcmss View Post
    As an ex GoldWing owner I actually like the little bit of noise the 1330 makes. Harley has made a killing selling noise.
  18. #43
    Sep 2014
    United States
    [QUOTE=arecibo50;1203390]
    Quote Originally Posted by arecibo50 View Post
    I agree with this. I had an '05 Honda Shadow Sabre - LOVED the bike but it was rather spartan. I added saddlebags, a windshield (then a better pop-off windshield), a rear rack that I put a Kuryakyn trunk on top of, sissy bar, highway bars, highway pegs, amplified speakers, GPS, fog lights, floorboards... and I realized I was trying to build a touring bike. So, I traded it for a Kawasaki Vulcan Voyager touring bike that had most of this built in.
    Buying low-end and farkling is expensive and time consuming. I enjoy the process but MOST of the time factory installed options are better done and less expensive.
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
  19. #44
    Aug 2015
    Canton, Ohio
    Quote Originally Posted by OverHillAndDale View Post
    I know full well the intention of the post and also very much appreciate it, both the intent and content. I find it constructive and helpful, what I have issues with are those that have purposeful intent to exude negativity in such a positive listing.
    Joe
  20. #45
    Mar 2012
    Florida Space Coast
    Hand brake.
  21. #46
    Nov 2015
    Tinley Park, Il
    Cup holder that does not mount to the handlebars so it would stay upright. I've had swivel ones that tilt too much or at the wrong time and spill. Mike
  22. #47
    Very Active Member JimVonBaden's Avatar
    NoVA
    Each year I make a post of the top things I'd like to see for the next model year. From what I understand of the 2017, here's my list for Can-Am for 2018.
    Thoughts and additions?
    Nailed it, though I doubt you will see many, if any, of them.
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
  23. #48
    Sep 2014
    USA
    While I would agree with some of items on the bucket list posted, I would like to see a Infotainment system similar to the Indian,Harley.
    Also like to see the turn signal buttons independant , one on each side handlebar like Harley uses. Found that type of setup worked well .
  24. #49
    Johnson, Vermont
    A spyder that doesn't have the cruiser riding position and isn't an RT. That's what I would like in 2018.
  25. #50
    NoVA
    Quote Originally Posted by Rob Rodriguez View Post
    Agreed, no boats or cruisers.
    Jim
    2013 ST-S (wife's)
