Results 1 to 22 of 22
    Invalid Emails
    Rotonda West,FL
    Default Charging voltage
    Is up at 14.4 when the spyder is running.
    12.5 spyder off.
    14.4 seams high anyone else seeing voltage this high?
    CapeSpyder
    Sent From my Note 5
    lake mary fl.
    Quote Originally Posted by CapeSpyder View Post
    12.5 spyder off.
    CapeSpyder
    Sent From my Note 5
    i don't think 14.5 is that high, but i been wrong before!
    Jun 2013
    queens ny
    around 14 volts is a good charging rate
    Sep 2014
    USA
    now go check you car voltage it will be about the same..Its normal
    Jul 2016
    Kitchener, Ontario
    14 volts is the proper voltage. Batteries always read more then they are rated for.
    Sent from my LG-H831 using Tapatalk
    Invalid Emails
    Rotonda West,FL
    Thanks all, wasnt sure never thought
    To check the suv.
    CapeSpyder
    Sent From my Note 5
    Harper, Texas
    I checked the 2014 RT (same motor) service manual. When the motor is at 4000 RPM you should see the voltage between 13.5 to 14.5 VDC.
    Quote Originally Posted by datispyder View Post
    That may be true, but that's not the reason for the 14+ volts while running. To charge a battery you push current through it backwards, so to speak, so the charging voltage has to be higher than the battery's normal voltage. If the battery has 12.5 volts then 12.5 volts while charging won't push any charging current through.
    Active Member woodyaa's Avatar
    Mar 2015
    Harvard, Il
    Very well put!!
    Aug 2015
    Canton, Ohio
    When i installed the guage on mine I was a little surprised also by the running voltage of 13.8 to 14.2. However after some logical deductions and coming to the same conclusions expressed above, you and i should now just relax and enjoy the Ryde.
    Joe
    Jul 2016
    Ranlo N. C.
    So can I get a trickel charger and plug into my 12 volt plug in my truck on my 2016 rts e6?? This keep battery charged when not in use for winter storage or seldom riding???
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Jan 2015
    Florence, Oregon
    Default Charging, charging!
    Quote Originally Posted by Ctider07 View Post
    I would not recommend using a "Trickle charger" for maintaining your battery on the as most trickle chargers are not regulated and typically deliver 1-2 amperes into the battery and that is too high for long term storage, the battery will boil dry if it doesn't short out first. As mention by several others a 12 Volt battery requires about 13.5 14.4 Volts to charge depending on the temperature, if the voltage goes above 15 Volts it will short out. Buy a good battery maintaining charger, the price is much cheaper than a new battery or a fire in the garage.
    Linden, CA
    That's right about where it should be..
    12.5 spyder off.
    CapeSpyder
    Sent From my Note 5
    No to a trickle charger! Get a battery charger/maintainer like a Battery Tender. NAPA also has a good one. The charging current output should be something on the order of 1.5 to 3 amps.
    Default No chargers.....
    The tender is most mentioned but you need any that profess to maintain the battery. These will keep the battery at the ready but if there is a drain will not be able to charge the battery. For that you will need a charger be it trickle or full blown charger...
    Very Active Member armyspydervet's Avatar
    Nov 2015
    Occoquan, VA
    My F3-T reads 14.4 when running.
    Chris
    2016 F3-T SE6
    Jul 2016
    Ranlo N. C.
    Hi to all. Just had a great day riding in gastonia nc and watching kids get toys from over 1000 bikers of all types. My first ride with them all and a well run program. Ran into some fellow spyder riders. I was told that a tender should be on my 2016 rts unit. I hoping someone can tell me a way to find this out without taking all my plastic off.?..
    Sent from my SAMSUNG-SM-T337A using Tapatalk
    Harper, Texas
    The tender won't be on your bike. A connector may be, if the dealer or previous owner put one on. Try a google search using the term "battery tender site:spyderlovers.com" (don't use the quotes) will take you to the several threads that have been written on the subject. Some use a fairly standard 2 wire pigtail as a connector, some use a cigarette lighter plug if one is available on the bike to connect the tender to the bike. I believe that the Deltran Battery Tender Jr is the standout in the tender market.
    Feb 2016
    HAWTHORNE nj
    Default wow
    I now feel a lot better, I just installed a volt meter and and reading 14.4 and I thought it was high. thanks guy I am good.....now I am looking to install some thing on the other side.thats another thread.......
    Sep 2014
    USA
    Speaking of battery tender I need to plug mine in haven't rode it in awhile and its going to snow today..Guess I am done riding for the season
    I let the Spyder, and my Lawn Tractor share the Battery Tender Junior in the off-Season Months.
    Typically; they each get to use it for about three weeks at a time.
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Almost the same
    The Spyder and my Honda Valkyrie share a tender at about 1 week a piece. The V-Max has a Shoria lithium batt that weighs nothing and stays charged for a few months. Wished they worked better on the With its constant slow drain.
    Kaos
    2014 RTS , Circuit Yellow
