Removing factory GPS unit
I want to remove my factory installed GPS but wanted to check if there are any connections that might be connected to any other options. I have the communications package and CB and can anyone tell me if the GPS connections are needed for those to work? Can I remove the GPS (Zumo 660) without it having any other options impacted?
The only other accessory I can think of that is tied to the GPS, is the cellphone interface cable. It uses the GPS harness microphone plug, so I think you are good to go.
Any interest in selling the GPS? Or is there a problem with it? Thanks
Quick Query
I too, have a 2012 Can Am Spyder RT-S, painted in pure magnesium. It came with neither the cb radio or the Garmin Zumo 660. So my question would be, did yours come with the communication's harness already installed as standard equipment?
Thanks for the offer but I am going to hold on to it, just taking it out right now and going to relocate it later on.
Mine came with the CB, Communication and GPSi nstalled
