Results 26 to 50 of 56
Thread: Clutch Shocker!
  1. #26
    Very Active Member JimVonBaden's Avatar
    NoVA
    Quote Originally Posted by Sam Mac View Post
    This is BS, time to get a lawyer. They took you're $$ for the extended warranty and now they don't want to stand behind the product. If you had 100,000 miles on it well maybe but for the miles you have on it give me a break.
    Like I said, carefully read the warranty book before you do anything. If it specifically calls out the clutch as excluded, no lawyer will touch it, unless they are unscrupulous and want their money up front.
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
  2. #27
    May 2013
    Edmonton Alberta, Canada
    Quote Originally Posted by JimVonBaden View Post
    I haven't checked it myself but I believe there is a disclaimer in the warranty stating that the clutch is not covered.
    The concern we've had including the dealer is that it wasn't worn but defective and some consideration should have been made to replace the faulty part.
    2014 RT-Ltd , Cognac
  3. #28
    Dec 2015
    Galax VA
    Well if 12,000 miles is the life expectancy of the clutch on a 1330 SE you would never get me to buy one. Think about a car that would only go 12,000 miles before the clutch's in a semi auto trans took a dump. No way they can tell me I need to eat the repair cost. Someone needs to explain how this can possibly be the operators fault. It's computer controlled, not like you were slipping a manual clutch. Sorry BRP stand up and do the right thing for your customer, it had a part failure I get that but no way is it the owners fault.
  4. #29
    Quote Originally Posted by Purple Guy View Post
    They did exchange several emails with BRP, with Steve or not I don't know but in the end they refused to budge.
    Did you talk with brpcare personally, or is this information just based on what the dealer said, or actually showed you.
    You should be privy to what is going on with your specific case by contact directly with brpcare.
    I am a firm believer of trust but verify.
    May 2013
    The owner of the Spyder was in direct contact with BRP
  6. #31
    Active Member robtdonna's Avatar
    Ellijay, Georgia, United States
    Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
    BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
    Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
  7. #32
    Sep 2016
    clark county indiana
    Default cost down
    well I might be late with this one , but if he goes too the dealer service , have the owner , take off all skins that is needed too do the work , on the cycle itself , this will knock down the price a good bit ! unless this would be considered a warranty expense that is covered ?
  8. #33
    NoVA
    Unfortunately that disclaimer is going to be hard to fight. You will need an independent analysis, from a respected tech, to have a shot at a case. Not so easy to get.
    Jim
    2013 ST-S (wife's)
  9. #34
    Apr 2015
    Brockville ONT
    This just dosn,t sound right.It should be under warranty and if not BRP should explain why it,s not.It,s a SE6 so how can you destroy the clutches unless your reving the engine then dropping it into 1st or reverse.I would love to ses a pic of the old clutches,s.I,msure there,s lots of machines out there with more miles and no problems and that pull a trailer.
    Bill
    2018 RT Anniversary , Brake pedal extended
  10. #35
    Houston
    While I disagree with it, the warranty coverage (lack thereof) on the clutch is very clear.
    Its not covered. Period.
    Its specifically called out in the warranty verbiage. Does not matter what caused it. Driver error, wrong or not serviced fluids, bad luck, defect in design. Does not matter. No coverage for the clutch.
    If BRP is unwilling to do a good faith repair for you, there is little you can do.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  11. #36
    Dec 2015
    Galax VA
    Well I didn't realize that the clutch is not covered. I'd still like someone to explain how it is not a defect when the operator has no control of it with the SE trans.
  12. #37
    Houston
    That was the point of my post. It may very well be a defect. Its still not covered. There is no warranty on the clutch. Most automotive warranties have the same type clause on clutches. Does not matter if they are computer controlled or not. Its a wear item like tires and brake pads. Some vehicles cover them all for some length of time but BRP chooses not to.
  13. #38
    Grain Valley, Missouri
    Quote Originally Posted by Ex Winger View Post
    Bill
    Wow, with just 5,000 miles on my F3T, it makes me cringe every time I shift gears. Especially into 1st or reverse, the 'clunking' is so hard and loud, it rocks the bike. My thought is always, "ouch"! I wonder what just sheared or broke off". Any connect here with what this discussion is about? Do I have any thing to be concerned about, within the next 15k + miles?
  14. #39
    Doesn't the US have over-riding Federal Laws that exclude 'defective or not-fit-for-purpose' items & components from weasel words in warranties like that?? Other countries do?!?
  15. #40
    Default WEAR ITEMS
    .... JC , then the engine is also a WEAR item !!! .... If yours had Blown up on the way home from the Dealer and they told you Sorry .....BRP doesn't cover - Wear items ......... I have a feeling You would not have accepted this.......And if your Theory is correct about the CLUTCH - WARRANTY thing ..... Then right after the OP paid for His Spyder and went out to go home with it and started it and the CLUTCH EXPLODED ( as in this instance ) .... The dealer could have told Him ( after 3 weeks ) SORRY but your zero miles Spyder Clutch isn't covered !!!! . But for another $1900 we can fix it right up.......... jmho........ Mike
  16. #41
    Houston
    Perhaps,
    How many lawyers do you have on retainer that are not doing other useful work?
  17. #42
    Here, it generally takes just one phone call to the applicable Ombudsman & usually within hours the manufacturer concerned is ringing you to arrange where & when you want the loaner delivered while they collect & fix your problem!! No need for Lawyers or much in the way of arguments in about 90% of defective component cases! And the majority of the rest never get past the 'mediated discussion' stage either!
  18. #43
    Houston
    Engine
    is a covered component. The clutch is not. Read the warranty.
    That said, there is a grace period for a new bike and defective wear components. BRP has decided that this case is beyond that point.
    I already said I disagree with it, but its the language of the warranty that was being discussed. Just because its not right does not mean they cannot get away with it.
  19. #44
    Feb 2009
    Ceresco, Michigan
    Bill
    Well, being the devils advocate here... someone with an SE could run too low on oil and burn the plates up, pull a trailer that is too heavy, etc.
  20. #45
    Aug 2016
    Prescott Valley , Az
    Great, sounds to me like my F3 T with 800 miles on it is left to " Luck" on if it has a large failure and likely wont be covered under warranty. Not at all what I was hoping the outcome would be once I started with this thread.
  21. #46
    Dec 2015
    Galax VA
    Well if BRP thinks that this is good customer service they can count me out as a future buyer. Keep it up and see what happens to sales.
  22. #47
    Feb 2009
    Ceresco, Michigan
    No Powersports company in the world is going to cover a clutch.
  23. #48
    Dec 2015
    Galax VA
    I guess he can look at it this way, it only cost him 16 cents a mile for clutch expense.
  24. #49
    Jun 2012
    Fairmont, Minnesota
    Quote Originally Posted by fritzer1 View Post
    The clunk is normal on any bike that has a wet clutch. It also really has nothing to do with the clutch. In a wet clutch, the driven plates are just being dragged around by the oil around the drive plates. If you want to eliminate this problem, start the bike in gear with the clutch disengaged. (Manual xmissions only)
  25. #50
    Active Member jegarh's Avatar
    Jul 2016
    maverick county, texas
    I don't know how I am going to handle any "repairs" on my new, to me, 2014 RTS SE6. I bought it with the extended warranty. I have always done all of my own "fixing". The only "warranty" work I have had done, and it was a recall, was replacement of the stator on my 2013 wr250r.
    My personal philosophy is "If a guy with a GED can do it then I can certainly learn how to do it as well since I have an advanced degree."
    I know that this isn't for everybody because I had a very good, close friend that had to be reminded which end of the screwdriver was the "business" end.
    I feel the OP's pain. Hmmmmmm ..........now where is that pesky clutch............................................ ..
    Jerry
    intelligence is genetic. Stupidity is an acquired skill.
