Results 1 to 9 of 9
    Active Member spyderspyke's Avatar
    May 2011
    wisconsin
    Default Only hitting on one
    I have a 2010 RS and the other day I started my bike and it was only hitting on one cylinder so I thought it was ether plugs or wires so I changed them but still the same thing any thoughts?
    Feb 2012
    Spring City,Utah
    Did you check the spark? Sounds like you make have a breakdown in the coil?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2011
    wisconsin
    no it has no spark to the back cylinder
    Feb 2012
    Spring City,Utah
    Then you have a problem further up the line from wires and plugs.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    May 2011
    wisconsin
    I already knew that but what else
    Default Coils....
    Only thing left is the coil or the power to the coil. After that you have the electronic ignition... if you have or can get a shop manual (on line $20.00) it will show you the steps to track it down...
    Jun 2011
    Aransas Pass Texas
    Default no fire
    my 09 did that and wound up having to replace the plugs and wires
    May 2011
    Charleston,SC
    On my '11 RS it was the ECM,it was replaced under BEST($50.)
    May 2011
    wisconsin
    thanks for the info
