Yeh, Bob, JC's comment can be scary. I'll find out in the not too distant future with the Dimple crankcase plug I installed at my last oil change. Oh well!
I did notice on my OEM crankcase plug that the Torx splines are only about 4.24 mm deep while the bored hole is a shade over 8 mm deep. If the splines were deeper it might prevent some rounding. Mo betta still, be certain the Torx bit is straignt and fully seated.
pic of broken dimple plug
Originally Posted by spyderryder53
that was me, my dimple plug broke in half right at the magnet the very first time I put it in and it WAS NOT over torqued.
I think some may be defective. VERY EXPENSIVE OIL CHANGE.
Leon
photo of dimple plug that broke off at magnet
2022 marsala red RTL
AND
2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
(Onboard) Lamonster Garage air compressor and intelliboost charger.
It baffles me, why folks will spend $20,000 or so on a motorcycle, and then balk at the cost of an aftermarket accessory for it...
What baffles me is why would a company who has to know about the plug problems keep charging as much as 20,000. _32,000 and not address the iissue and solve the problem that would probably not cost them a dollar more to solve.
Kenn
........... JC, I have the GOLD brand and I've seen pics of the Magnet in the Dimple brand ...... It looks like the Dimple has a larger magnet and I think this is the problem .......the larger magnet causes them to drill a larger hole in the plug , thus making the walls thinner, thus the failure...................jmho.......Mike
This may very well be true. I have not seen a snapped off gold plug. What you say about a smaller magnet would make sense as it leaves more metal at the weakest point.
AND
GOLD VS DIMPLE
Originally Posted by beefybudds
That is the exact same spot my dimple plug snapped. I purchased the gold plugs and purchased another set of dimple plugs to compare the 2. The gold plugs are a better quality in my opinion. I felt confident enough with them that I installed then in my Spyder. I sold my dimple plug.
The broken half with the magnet of my dimple is still in my clutch cover that I had to have replaced at a cost of $1100.
The owner of dimple "Richard" told me there was no way his plug would snap under correct torque but I thing he is wrong.
Since you have BOTH close at hand ....is the magnet in the GOLD PLUG smaller then the DIMPLE ? ? ? ......Thanks ......Mike
BROKEN OIL PLUG
Originally Posted by jcthorne
On your F3, one plug is torx, the other is hex. What sort of tool were you using? You need a torx drive socket and ratchet, not a key. If the head striped out, the wrong tool was used or not fully inserted.
I do not recommend the dimple plugs. They are worse than the OEM in terms of failure. Having done MANY spyder oil changes, the OEM plugs are just fine if you use the right tools to remove and install them. Dimple refused to stand behind their defective product. Once you see a snapped off Dimple plug, its easy to see why they fail from the very thin wall under the o-ring. Bad product.
I stand corrected.. I guess the other dimple plug with the o-rings is also failing.
AND
Oil Plug
Just a question: Why are dimple bolts so expensive? Is Dimple a bolt manufactuer or just a jobber?
I made my own oil plugs with magnets and use magnets on the out side of the oil reserve. Prevention
is cheap.
Good Luck
TECHS
So far, so good..
As long as the "red wagon" is ready to go, parts don't fall off (blue threadlok is my friend), and I can show my wife that my time is cheaper than the shop time I get to practice my wrenchin!
And I can buy a few new tools along the way.. it's all good! (thanks to the hints and guidance from SL)
I got the "gold plugs" today and put them in. They fit great, look great, and work well. I am so glad to have gotten them today, my Spyder sat for 3 days and I couldn't ride it. The plugs are so much easier to tighten and remove, they have a head on each. One is a 15mm and the other is a 17 mm. In about 9000 miles, I am sure they will be very easy to remove.
BUT STILL DO THIS
........Even tho they have that great HEX head ..... when you put the socket on give it a decent rap with a hammer to break the varnish SEAL........Mike
I once opined to her, that it would be nice to change the Spyder's oil on my own...
It got ReAlLy ugly!
There's not a whole lot of things, that I wish I had never said... THAT; was one of them!
I guess I am lucky. When it comes to any of our vehicles, as long as I don't get us stranded, Pebbles don't care what I do to our machines.
