Results 1 to 17 of 17
    Nov 2014
    TriCities, WA
    Default Solution for blind people seeing dash info
    Having a difficult time seeing the info on the dash, I ordered up this item: http://www.ebay.com/itm/121648340413...%3AMEBIDX%3AIT This is 3x
    Cut it down to 4"x3.5" I cut it out of the center, but now realize that I could have used the side. I also could have made it about 4.5"x4". Used some 3/8" plastic with peel and stick stuff and I also used velcro. Adjust distance out from dash for optimum magnification. Of course if the sun is behind you there is still an issue seeing the info. Sunglasses also can be a problem.
    Better at night
    Default Well done..!!
    looks like it dies a good job. Hope it holds up in the summer sun... guess you remove it if parked outside...
    Jun 2013
    queens ny
    great idea
    109 Outside, and 102 Inside??
    You've got some serious heat working there!
    ...And I could actually read that without a magnifying glass!
    Jun 2013
    queens ny
    i liked your idea so much, i ordered a sheet of it on amazon and i am going to trim and install it when i get it
    Nov 2014
    TriCities, WA
    That was 109 at 6PM and 102 at 9PM. We have had over 100 for 2-3 weeks now with no let up. While joining up with the North to Alaska bunch it was 115. Bike handled great and with a couple of home made cool vest not so bad. A dew rag keeps the sweat from the helmet.
    Today ran around some 105 the "lens" hasn't moved.
    Nov 2014
    TriCities, WA
    Default Updated Version
    I didn't make it wide enough and it was too low at the top, so I bought another sheet, this time without the lighted plastic for $4 shipped. It maybe too wide now as I don't see the RPMs and Speed analog. I'm still testing until I figure how much to trim off.
    Quote Originally Posted by pitzerwm View Post
    What is the device where the analog temperature gauge used to go? Thanks.
    2010 RTS-SE, Orbital Blue
    Sep 2009
    illinois
    It appears to be a voltmeter.
    Nov 2014
    TriCities, WA
    That is a power plug, with a digital voltage thing that plugs into the plug. This is like it. http://www.ebay.com/itm/DIGITAL-DUAL...item5b15fe5b02
    Active Member Sempyder's Avatar
    Kalamazoo
    Better solution for blind people, if your blind don't drive.
    I like the power plug!
    Sempert out,
    Sempyder out,
    Nov 2014
    TriCities, WA
    Default UPDATE
    After using it a bit, I made the following changes: I needed to use super glue on the peel and stick Velcro as the heat melted the sticky stuff. Adding super glue seems to have solved that issue. Also the way fennel lens are they only really work straight on, so I needed to cut it down a little so that the analog MPH and RPMs can be seen at the sides. The end result is 5.5" wide and about the same top to bottom.
    Quote Originally Posted by cuznjohn View Post
    John,
    Don't forget to remove it before going to the bathroom; you'll just scare yourself!
    Jun 2015
    North Bay, Ontario CANADA
    Better at night
    It's a great idea but watch you don't get the sun's rays hitting it in the right spot so you burn a hole in your cluster. These magnifying glasses can be used to start fires too! I had a friend with a CanAm ATV install one in front of his GPS to read the screen better. One day he moved the magnifier out of the way while we were stopped to take a break. Next thing I saw smoke coming from his dash plastic. He now has a souvenir hole there to remind him of how powerful the sun's rays can be through a magnifying glass!
    Jun 2014
    ny
    i still need it in braille
    Sep 2016
    Canada, Ontario
    Better at night
    What a great idea!!
    Sep 2016
    clark county indiana
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    good one !
