Results 1 to 4 of 4
    Feb 2015
    NB Canada
    Default VSS Fault after replacing rear tire/wheel
    I have a 2015 F3S and I did some searching and can't find the issue.
    I changed the rear tire. After I reinstalled the wheel etc the vss and abs lights are on and limp mode.
    Anyone have a cure for this. Or how to reset?
    I did the change not dealer.
    Stiff
    Sent on Note 5 in Taptalk
    2011 RT Limited , White
    Feb 2015
    NB Canada
    Never mind. I'm a moron. Lol. I had my F3 on ramps on the front. Lifted the back and used the throttle to move the back tire to check the belt. And they came on. As soon as I pulled off the ramps it went away.
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by _..stiffler.. View Post
    Tis a warm fuzzy feeling when we solve our own problems!
    ​Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Oct 2020
    Arizona
    Light bulb moment!!! Put new tire on and same same! If I remove rear sensor can I run it to get the belt alignment close.
