Results 1 to 20 of 20
    Jul 2016
    Braham, MN
    Default Life Expectancy of the Belt
    Good morning everyone.
    Was thinking about the belt lately. Only 14,500 miles on our '13, but I'm new to this so I ask a lot of questions. I read a few weeks ago that sprocket replacement is recommended when you replace the belt, which makes it an expen$ive endeavor to undertake. What's the average life expectancy of a belt assuming you don't pick up a rock?
    Our belt looks great so far, but of course it's always nice to know what to expect.
    Default BELT
    250,000 miles + or - ............... Mike
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    so, who has actually replaced one because of long life only? an did
    you replace 1 or both sprockets? inquiring minds want to know.
    irv
    [joyce & irvin toms]
    Jul 2008
    Natchez, Ms
    I have to ryde on less than perfect roads and a rock can get wedged in the sprocket. My Spyder caused wrist disease makes my hand twist too hard and sometimes I need a new belt! Sprocket is always fine!
    You might want to talk to Ann (SpyderAnn01) about this. She's either at, or getting close to: 90,000 miles on her 2014 RT-S
    Jun 2010
    Las Vegas
    I'm at 88,000 miles on my 14 RT and I just changed my rear tire and inspected the belt. It looks great.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2016
    Braham, MN
    Wow, that's great to hear Ann!
    So the big issue is rock damage. Do you guys typically replace sprockets when you replace the belt? I read somewhere that it's recommended.
    Default Not to worry...
    It will out last you... under normal conditions as you said both sprokets and belt will last 100's of thousands. Most folks have a new spyder begore the belt wears out...
    United States
    Since you have a '13 the belt is different from the the '14's. So your life on the belt may vary. Just periodically inspect it for cracks, check the sprockets for rocks (belt killer for sure). Our State does chip seal and anytime I get caught on one of those roads I will pull over when off of it and check the sprockets. The combination of sticky tar-covered rocks and the sprockets can get one lodged pretty quick. Do the same thing if I have to do gravel also. I have 31k and still perfect on my '14 RT.
    Invalid Emails
    May 2010
    Chelan, WA .. the dry side!!
    Default Have you added...
    Quote Originally Posted by Jester View Post
    Spyderpops ROCK GUARD....I also live on gravel road....so far the rock guards have saved me...plus I drive reallllllly slow in and out...6 years and lots of miles...just sayin'
    Jun 2013
    queens ny
    my friend changed his belt on his Yamaha, and in a week it broke on him when we were riding. so you never know
    Belt longevity should be over 100K in regular use. See Spyder Ann above.
    I have replaced two belts. Both due to rock damage. One rock picked up going on a gravel drive to inspect a campground, and the other in my driveway when I buried the rear wheel trying to get unstuck in my eagerness to get out during early spring breakup.
    Both times around $350 to replace. The tow from my home was extra.
    Spyderpops belt guard is a helper. Driving slow through rocks is also recommended.
    Active Member Jheck's Avatar
    Jun 2015
    sherburne, ny
    Ann, if you don't mind me asking, how many rear tires you been thru.? And what size and kind are you using?
    Aug 2012
    CO
    Spyderpops rock guard did not prevent our belt from picking up a stone. It may have delayed the inevitable. Still, that's the only reason most belts get replaced; or from too many drag launches. Age of the belt is rarely a factor in replacement.
    JLohPhotos
    2008 GS , Millennium Yellow
    Very Active Member otter28169's Avatar
    Aug 2012
    East Pharsalia, NY
    I ride my RS-S like the rear fender is on fire, and I am currently on my fifth rear tire. When I replaced the rear the last time, I checked the belt and it looks good. These belts must be pretty sturdy, because I ride like an most of the time.
    Just sayin'............
    Three in the garage, and I think I can fit at least one more in.....and then we will have to build another garage.
    The roads in NY are so bad that I am glad we bought a Ryker Rally
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    Quote Originally Posted by TomB985 View Post
    No you dont have to replace the sprockets when you replace the belt.
    You do on chain driven bikes but not belt ones.
    Jun 2010
    Las Vegas
    Quote Originally Posted by Jheck View Post
    I believe that I just installed #9. The first tire was the soft Kenda that didn't last long. I also tested 3 Arachnid tires and got poor mileage out of them. I've had 2 Kumhos and 2 General Altimax and 1 Yokohama S drive, and a partridge in a pear tree.
    2010 RT- 622
    United States
    So Ann, what has been your favorite for handling/mileage?? We are going to need to replace our Michelin Hydroedge in 5k miles, or so. It has 26k on it and has worked very well, but can't get anymore of them.
    Active Member WEB-WVR's Avatar
    Sep 2009
    Albany, Oregon
    SO......the big question is which tire did you like the best ?
    Craig From Albany Oregon
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    Awesome to know the belt is that good... Wow to Ann!
    Live, Love, and Ride! God Bless!
