New Antenna from Spyderpops
New antenna with better range and much more solid, Just got this from Spyderpops and it comes with a new style boot that won't fly off and works with half or full cover without breaking, what do you think, looks good don't it?
Several of us were at Spyderpops yesterday and had them installed, very solid and good range. I especially like the new "boot" that is nice and tight.
Cruzr Joe
NEW ANTENNA
2013 Viper Red RT S-SE5 All 48 states on a Gold Wing now I'm working on getting all on a
Very nice! Wonder if these will work on F3-T as well?
Yes, do tell! I'd be interested if it will.
Harvey said that he has not had a F3 touring bike in yet to try it on.
Cruzr Joe
Joe,
Has Harvey told what the pricing is going to be?
$25.00 shipped to you in the lower 48. He now has them on his website.
Cruzr Joe
Very nice...
Looks like the perfect solution to all the antenna problems being had by many...congrats
How does it mount? The boot?
Cruzr Joe
$24.95 shipped.
How about if we just include it in the payment, and tell Harvey to forward them on to you?
Craig From Albany Oregon
Originally Posted by WEB-WVR
I am wondering this also. Do you have to remove the tuperware, get to the backside of the tuperware to remove nut and rewire/re-plug. Or can it all be done from the outside as with some of the other antenna replacements ?
Will this work to replace the long whip antennas like on my stock 2014 ST-L ?
Thanks !
This is what I got from Harvey
The antenna is a quick change out, using a 7mm open end wrench to get the old one out and then use blue/medium Locktite when you put the new one in. The grommet will slide over the antenna after you get it installed and I installed the adapter in the antenna first using the 3mm socket to tighten it all the way then screwed the assembly into the hole on the Spyder.
The grommet seems to be a little hard to get it snapped into place but if you push in the bottom first then you can use more force to push in the top. It really fits tight and flush. I installed 4 yesterday and everyone was very happy with it.,
Are they going to be at Spyder Quest next weekend?
Maybe check with them to be sure.
aaaahhhh ! sold out already. shipping mine out tuesday[and a couple of
other things]. irv
[joyce & irvin toms]
I must have gotten the last one...
other things]. irv
Let us know how it works...
But will Joe be there also?
Joe can't make it to Spyderquest
New Antenna
Joe,
I like the new antenna on your spyder.
Deanna
Current Spyder - 2023 F3 LTD Special - Mineral Blue
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Front Fairing Service Access Door Covers (Carbon Fiber Domed Black)
Sway Bar with Links
Rolo Laser Alignment
Half Cover
A-arm Daytime Dual Color LED Running Lights with Blinker Module
Marinco 12 Volt Power Receptacle with polarized leads & slide lock
Show Chrome Trunk Shock
LED'S - Run/Turn/Brake Rear
Former Spyder - 2014 RTS SE6 Cognac - SOLD
First Spyder - 2012 RTS-SE5 Quantum Metallic Blue - TRADED UP
