Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Thread: Trailer for rt
  1. #26
    Jun 2015
    Lees Summit, MO
    Quote Originally Posted by Just Paige View Post
    Hi all, I'm new so forgive me for hijacking this thread to ask a trailer question. I have a 2012 RT and am wondering how many of you with trailers use them frequently or only a few times a year? Is it worth purchasing one or can they be rented?
    Thanks!
    I only use ours maybe two or three times a year. Went with the harbor freight trailer.
    2015 Special Edition , Red and black
  2. #27
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    I use mine once or twice/year. If I'm going overnight with my wife I need. Will also need it when I go cross country after I retire in 4 years!
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
  3. #28
    I'm a contrarian sometimes. Here's my approach to owning & using a trailer!
    http://www.spyderlovers.com/forums/s...ight=versatile
  4. #29
    Sep 2007
    Rome, WI and Mayfield, KY
    I use mine only when I travel with my wife. I want her to be comfortable so she doesn't have to pack light. I split the difference and bought a blemish version of the following on eBay for $1200. Decent looking but not crazy expensive.
    http://theusatrailerstore.com/blackh...cycle-trailer/
    Lucky
    2015 RTS SE6
    2008 Harley Ultra
    1999 BMW R1200C
    1986 Harley Electraglide
  5. #30
    Jan 2013
    Ponchatoula, Louisiana
    Can you share the various components that you used to build your trailer?
    Quote Originally Posted by CMA/IBA_rider View Post
    Any motorcycle trailer will work. Or custom motorcycle trailer. I pull one that I made
  6. #31
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    Currently on sale for $379.99, spend another $100.00 or so changing out the lights to LED, some paint if you wish, etc. and you have a good cargo trailer.
    http://www.harborfreight.com/600-lb-...ler-62644.html
    Current:
    2016 Honda CTX700 DCT ABS (faring model)
    Kip Moto SherpaX Cargo Trailer
    Wife Has:
    2014 Can-Am Spyder RT Limited
    2016 Lees-ure Lite Camping Trailer
    Previous:
    2013 Can-Am Spyder RS SE5, zoom-zoom!
    2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
  7. #32
    Active Member lois35's Avatar
    Sep 2015
    SC
    ok got my hitch installed. bought a harbor freight trailer. installed a show chrome harness. my question is. i have 5 wires from the harness and have a 4 flat plug coming from trailer. so how do i connected them. i bought a four female but i dont have anywhere to plug in the brake lights. i was trying to see if i could get a 5 pole to 4 flat but i dont think taht would work either. so i know i can add addition light for brakes but was wondering if anyone hooked theirs up with everything working. i would appreciate any info
    Lois
    2015 Pearl White RT Limited
  8. #33
    Quote Originally Posted by lois35 View Post
    Lois
    You CANNOT just simply plug the 4 wire trailer harness into the 5 pole connector with any kind of adapter plug. You will need to get a 5 wire to 4 wire converter module and connect it to the output of the isolator in the harness you got from Show Chrome. They're available in many places such as auto parts stores or trailer supply stores. Connect a 4 wire flat plug to the output wires and you're all set.
  9. #34
    Sep 2014
    United States
    I think this is what you're looking for...
    https://www.etrailer.com/Custom-Fit-.../56146KIT.html
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
  10. #35
    Sep 2015
    SC
    i want to thank everyone for their help. went and got a converter module. installed it tonight and it works like a charm!! appreciate the help.
  11. #36
    Thanks for letting us know!
  12. #37
    Apr 2016
    ontario cda
    Default my camper works
    Quote Originally Posted by sjn7708 View Post
    Can you use a trailer other than the Can-Am trailer on an RT 2015. I heard that using a trailer other than a Can-Am trailer interferes with the electronics somehow. I have been unable to find a used Can-Am trailer
    I heard the same thing my bike was wired by the dealer I had to by the front wire harness from a freedom trailer to get the proper plug I then cut the harness to length and installed a plug to match my mini-mate camper so far so good
  13. #38
    Mar 2015
    Advance, NC
    Quote Originally Posted by JayD View Post
    Don't use BRP wiring harness. Go to show chrome and get one. It goes straight to battery and bypasses the spyder electronics.
    Sent from my SM-N900V using Tapatalk
    +1 Amen!
  14. #39
    Sep 2016
    US. ohio n/e
    Quote Originally Posted by Deer Slayer View Post
    +1 Amen!
    I installed the show chrome trailer harness...works grt....its a parallel relay systems make sure u leave the fuse in a access area. ..i put mine under set
    Sent from my LGLS675 using Tapatalk
  15. #40
    Sep 2016
    US. ohio n/e
    Quote Originally Posted by amelectricdavid View Post
    Its also 5 wire flat...u can bye a 4wire converter plug
Tags for this Thread
