Wet Spyder
I'm sure by now you have heard about the flooding here in South Louisiana. Two of my vehicle are totalled from water damage. My spyder wasn't submerged but I believe the water level was above the fuse box. I cranked the bike to move it before I realized that it too may have flood damage. Any opinions?
Keep 3 Down..!!!
The saddle bags also contained water..
Keep 3 Down..!!!
Bummer...
Make sure it is dried out before you do anymore cranking. Pull the exhaust off and drain it. Pull the battery charge and test it. check all fuses and reseat them. If the water was above the fuel breathing systems you may have to drain the tank and refill. Good luck hope nothing major was damaged
The panels need to come off and everything washed as soon as possible. You don't know what was in the water and where debris has gotten into. It wasn't saltwater was it? If the water was not above the air box. The engine will be fine. Exhaust needs to be dumped out. The fuse box covers need to come off and dried out. Major connectors for main modules removed and dried out if water got into them.
It will likely be fine just a lot of time and maybe a few parts.
Really sorry to hear hope the advice you get here helps!
Live, Love, and Ride! God Bless!
just checked the fuse compartments and both were totally dry, no sign of moisture.
Thanks for all the help!!!!
Keep 3 Down..!!!
INDIANS
YOU NEED TO TELL THE INDIANS TO STOP DANCING........
DANG! ! ! that just isn't funny.... i wish you all a quick recovery...
SPYD3R
Originally Posted by finless
Your not the only one! A guy named Andy on FB.
Bob
Man how I HATE to see pictures like that one. Floods are terrible things to have to deal with. My thoughts are with all the folks down there in Louisiana who were affected.
We are praying for you and others. If you have full coverage you might let your insurance company deal with it. There are so many connections that can get wet and down the road issues may show up. Just my thoughts.
that stinks but they are only vehicles,hope family and friends are all ok and good luck
If you have your spyder under the water you must clean it properly and quickly.
our prayers go out to everyone down there !!!!! irv and joyce
[joyce & irvin toms]
More important things to be concerned about for those involved than a Spyder. Many have lost everything that they have. Many have no insurance. This is a major life altering situation for many. Let's put this in perspective. Prayers to all of those affected in LA.
WD 40
Spray it every where you can & them wipe off or blow dry wi air
I love R&R put another dime in the jukebox baby!
