Results 1 to 23 of 23
Thread: Oil usage
    Invalid Emails
    May 2016
    NW Washington State
    Default Oil usage
    Is there a 'normal' amount of oil this engine will use? Just curious, I have 1500 miles on mine and it still indicates right at the full. Doesn't seem to have used any. I'm hoping it never does but is there an average amount of oil used and if so at what mileage will it occur?
    Thanks.
    Nov 2015
    Myerstown, Pennsylvania
    Default Other threads....
    I think I've seen other threads on here about oil usage. The 1330 doesn't use the oil like the 998 does is what I remember seeing. Anyone else want to add to this??
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Quote Originally Posted by Habib View Post
    Thanks.
    12500 miles 0 oil used
    Jul 2015
    Kamloops B C
    Thanks.
    16000 Km's (10000 Miles) and No oil usage!
    Neil
    2016 RTE6 , Black
    The 1330 engine (which you have) does not seem to use any oil. The 998 does use oil.
    United States
    29,600 miles on our 1330 triple and 0 oil used.
    Invalid Emails
    May 2016
    NW Washington State
    Thank you all, I'll just check it every couple thousand and not worry.
    Active Member SilverFox1's Avatar
    Dec 2010
    Chelmsford, Ontario
    Hi habib
    Don't you think that checking every 2000 miles is a bit of a stretch? Just saying. A lot can happen in between. You could do a lot of damage to your motor, but then again, what do I know? Good luck.
    SilverFox
    If you don't change anything,,,
    nothing is going to change!
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Amount of oil used to date (1.5 years) has been
    ZERO!
    AJ
    Thanks.
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Feb 2015
    Las Vegas
    I check mine religiously every 5000 miles
    AJ
    Quote Originally Posted by SilverFox1 View Post
    Hi habib
    SilverFox
    2014 RT-S
    2014 RT/S , Black
    Clermont, Florida
    Thanks.
    I have 97000 miles on 1330 engines and have never added a drop of oil between maintenance intervals
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    Quote Originally Posted by BikerDoc View Post
    97,000??
    Default Not to worry...
    You have the 1330 engine that does not use oil between changes. They had some first run engines with leaks but all has been fixed. Just us 998 owners get to rag on oil use...not you..!!!
    Nov 2015
    Default Owners manual....
    The owners manual states to check oil every 1000 miles.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Apr 2014
    Beloit Kansas
    keep checking it, if you got nothing better to do. These 1330's are notoriously oil tight. I followed mine until shortly after the 1st
    service, and now don't sweat it. If it never used a drop of "break in" oil.....draw your own conclusion. They are so good in this regard.
    Invalid Emails
    May 2016
    NW Washington State
    Checking the oil is quick and easy. After further advice I'll check it at around 1000 miles.
    I want to get to 100k.
    Nov 2014
    TriCities, WA
    There is also a light on the dash, if you have a problem.
    You can't begin to compare oil usage between the 998s, and the 1330s...
    I think that the container of BRP oil that I bought for topping off the tank; is going to die of loneliness!
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Saves space in the side bag... don't need to carry oil on trips
    Agree, both our 15's have been keeping oil level constant. Just the chore of getting it right after a service, and then good 'til the next service. I still check it hot when we pull into the garage after a ride... about once a week or so.
    2015 RT , OEM Black Gloss
    Aug 2012
    Central Coast, CA
    24000 on my old 998 and it used about a quart every 3000 miles. My 2014 with the ACE motor and 28000 miles uses no oil between changes.
    Sent from my SM-T710 using Tapatalk
    2020 RTL SE6
    You might want to stop every once in a while, and drain a little bit out...
    That'll keep it from overflowing the tank!
    Invalid Emails
    May 2016
    NW Washington State
    Are there any 998 owners that want to buy some good oil?
    I you ride with a couple of "998s"; they WILL use up your excess!
