Results 26 to 50 of 51
  1. #26
    Jun 2010
    Las Vegas
    Quote Originally Posted by Joyce47 View Post
    one of shawn smoaks videos contains a rant on aftermarket leds. does
    not like people splicing wires to install and either does the computer.--irv
    It seems that he may have been wrong... I don't remember the exact details, but I believe that there turned out to be a completely different source, for the problem that caused the rant.
    A bit more research is in order...
    Bob, you are correct on that. Shawn made a video and blamed one persons issues on bad LEDs and it wasn't the case at all. He had two bikes confused.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
  2. #27
    Active Member remark2013's Avatar
    Sep 2014
    Los Alamos, New Mexico
    We have the Spyderpops lighted bump skid and been having all kinds of problems with the LED's. I give Harvey all kinds of props, I call or email him about the problem and he replies.....new ones on the way! That my friends is customer service at it finest!!!!! It does get annoying having to replace them about every month or two. Next time I might try heating it up before installing the new light strip.
    Kent
    Ride Safe All
    2014 RT Limited (Charlotte) in Cognac, Kuryakyn Grips,Tri-Axis Handle Bars, Rivco Armrests, a "finless" BT Dongle, TricLed Fender, Saddlebag, 3rd & 4th brake Lights, Custom Dynamics "Magic Strobes Brake Flasher", BajaRon Sway Bar & Spring Adjusters, Lighted Bumpskid, Rivco Highway Pegs, Rivco Cup Holders and Baker Built Air Wings. 215/60R-15 General Altimax Rt rear tire. 155/60R15 Kumho Solus front tires.
  3. #28
    Nov 2014
    TriCities, WA
    IMO one of the issues is the Chinese dumping sub par LEDs on manufactures that were getting premium LEDs. It's not easy to test for that problem.
    I think that installing them where the bumpskid and the tupperware meet, leaving a little room for expansion and contraction is the best solution. You can buy the strips 5m for <$20, use a plug and if they fail its cheap and easy to replace.
  4. #29
    Apr 2013
    Atkins, Arkansas
    Default Did not have that in my days
    At least not the Bumpskid with LED lights, think they came shortly after Spyderfest 2014 where I had my Bumpskid installed. Found some super thin LED's at Oznium they are SMD3528 0.18in with 30 LED's per foot and waterproof. I clean the surface with denatured alcohol and a Q-tip and then use a 3M 94 Primer Tape Pen. These super thin LED's can be trimmed after every three LED's.
  5. #30
    Mar 2013
    Marion, Arkansas
    Well with the current LED bumpskid, there are 60 LED's per foot at least thats whats on mine now. But the ones you have look pretty bright. Do you know if the LED's are the 5050 or 5630?
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
  6. #31
    Apr 2013
    Atkins, Arkansas
    They are SMD 3528. I had to pull my white and switched to amber due to Virginia Code Issue with more that 5 white front lights. I have them attached through a 4 channel controller so I can dim them way down.
    The 5050 are bigger and brighter however bulkier and generate more heat than the smaller 3528 chip. I have been buying the 16 ft rolls and make my own ends with clip on pigtails and Liquid Tape.
  7. #32
    Houston
    Quote Originally Posted by Dragonfly View Post
    Almost every higher end new car and the Spyder RT all have more than 5 white lights up front as delivered. They meet DOT standards. VA cannot just decide they are illegal. The RT has 6, my wifes explorer has more than a dozen. The law you refer to is outdated, contrary to federal standards and unenforceable.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  8. #33
    Apr 2013
    Atkins, Arkansas
    Not disagreeing but tell that to the Superintendent of State Police who is the approval authority in Virginia. (Thanks to former Gov. Tim Kaine and the likes) Any lights that are not OEM or ASE Certified have to be approved by the State Police.
  9. #34
    Invalid Emails
    Rotonda West,FL
    Do they come with the 3m tape already on them?
  10. #35
    Apr 2013
    Atkins, Arkansas
    Quote Originally Posted by CapeSpyder View Post
    Yes they do, I would think that almost all flexible LED Strips on the market have the tape already attached.
  11. #36
    Active Member WEB-WVR's Avatar
    Sep 2009
    Albany, Oregon
    Quote Originally Posted by Ex-Rocket View Post
    Just curious if others are having problems with the LED's on their bumpskids. At Spyderfest 2015 I had installed a new lighted bumpskid. Well the very next day the LED's quit working or about 3/4 of them did. Went back to vendor and he put on another one. That one lasted maybe 4 months and again 3/4 of the LED's quit working. So by now the manufacture had changed to a different LED lights, so the vendor sent me a updated version that has the LED's that are now replacable. Again the LED's only lasted another 3 months or so. Vendor sent me the LED's and I installed them this time which brings me up to present. The LED's are out again with only about 1/4 of them lite up. I'm about fed up with the lighted bumpskip. Does anybody know if there is a better quality LED's that will last longer than 3 or 4 months???? I really love the looks but if I have to change this out every 3 or 4 months. Maybe I'm just snake bit. And no nothing has hit the bumpskid since the lights were working when the bike was parked last and when I got on it to ride, the LED's were out. Please help with suggestions.
    That is why I went with the non lighted BumpSkid: I have seen too many light strips that have sections burn out. I was also concerned that any scraping, bottoming out or that squirrel you hit going 60 mph....would just break the light strip anyway. I do not ride that often at night anyway.
    WHAT I WOULD LIKE TO SEE: is some clear white flashing strobes (like on Police vehicles) that would mount in the headlight assembly and some located on both sides of the Spyder....switch activated. So that you could activate it in high risk areas, such as; going through an intersection, sudden slowing traffic, etc. I know.....may not be legal, but I would do it anyway to stay alive !
    Craig From Albany Oregon
  12. #37
    Invalid Emails
    Rotonda West,FL
    I sent an email to Spyderpop 1/3 of the new set just went out and im looking at alliterative
    CapeSpyder
    Sent From my Note 5
  13. #38
    Apr 2016
    Tennessee
    Default LEDS OUT
    Just got mine in Maggie Valley, on a ride yesterday I realized they weren't on. I ran the wire to see if it was lose somewhere, and when I got back to the edge of the skip where the wire and LEDS meet, I moved it and they came on. There is a short in the wire right there. Now my question is do I have to have a whole new led strip or can I rewire the LEDS. ??? I emailed spyderpops just a few minutes ago...haven't heard back yet.
    Any Ideas.... ?
  14. #39
    Apr 2016
    Tennessee
    Default GREAT CUSTOMER SERVICE
    Got an email from Harvey in less than 15 minutes saying a replacement strip is on the way....that is the way to keep customers happy !
  15. #40
    Feb 2012
    Spring City,Utah
    so now that a replacement strip is on the way and you know where the break is in your current strip why don't you put a drop of solder on it and see if it will fix the problem. If so keep the new strip for a backup and run the old strip till it dies again. And let us know how the project went if you decide to do it.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  16. #41
    Apr 2016
    Tennessee
    Default THAT'S A GREAT IDEA...
    If I can get up under it, I will try that tonight...
  17. #42
    Very Active Member zuni's Avatar
    Mar 2014
    JAX FL
    Quote Originally Posted by pitzerwm View Post
    That's what I did. Has worked great for 2+ years now.
    CJ JAX
  18. #43
    Nov 2015
    SC
    Cool Great support from spyderpops
    I had mine fail after about 6 months. Spyderpops sent me a new set no questions asked. They have been perfect since then. He is easy to work with and is a great vendor.
  19. #44
    Mar 2013
    Marion, Arkansas
    Spyderpops is the best.
  20. #45
    Apr 2016
    Tennessee
    Default SPYDERPOPPING AGAIN
    HARVEY GOT ME THE REPLACEMENT LED STRIP THE NEXT DAY. GOT THEM ON AND I'M SPYDERPOPPIN AGAIN !
    THANKS FOR THE GREAT CUSTOMER SERVICE HARVEY !!
  21. #46
    I had installed my new Bumpskid right before SpyderFest (6 Months ago...)
    Yesterday; half of it was out...
    I guess that I'll have to get in touch with Harvey, and buy a new string of lights.
    Does anyone know how much they are?
  22. #47
    Active Member cyclekid58's Avatar
    Sep 2014
    Post Falls Idaho
    Default Lighted Bumpskid
    Quote Originally Posted by zuni View Post
    CJ JAX
    I did the same thing only with the knightrider LED from TricLed, mounted above the bumpskid is more protected and using the knightrider I have a variety of flash patterns for parades or steady on for general use, it has worked flawlessly.
    Greetings from Idaho
    2014 RT-S,
    Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
    2014 RT , White (Mine) Cognac (wifes)
  23. #48
    Invalid Emails
    Rotonda West,FL
    Just send Spyderpops a message and they'll send a replacement set. N/c so far under warrenty??
    CapeSpyder
    Sent From my Note 5
  24. #49
    Thanks!
    I hate like Hell to do that to Harvey...
  25. #50
    Invalid Emails
    Rotonda West,FL
    I know, i have had 2 sets go partially out 😣
    CapeSpyder
    Sent From my Note 5
