Page 1 of 3 123 LastLast
Results 1 to 25 of 70
    Kennesaw, GA (Atlanta Area)
    Default Rear Tire - What is the Best Option
    All,
    If I do a search on this site, there are numerous threads on replacing the rear tire...so in order to narrow down my search, and give everyone a chance to voice their opinion again but directed to me, I thought I'd throw out the almighty question and get to the point:
    I'm needing to replace the rear OEM tire on my 2014-RTS-SM6. I have 5900 miles on it and it's worn out! What I am looking for are recommendations or best options on replacing the rear tire; Brand, Size, etc.
    I know I'm asking for a lot of opinions, but I know I'm going to get some good responses and some good guidance too.
    Dealer wants $189 for the OEM and $128 to install it...options here too, please. Thanks in advance as always!
    Bryant, Arkansas
    I use the Kuhmo on the rear, the OEM tire (Kenda) are only two ply, the Kuhmo is 4 ply and rides great. I use the OEM tires on the front and usually get 23,000 +
    Cruzr Joe
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Default Tires
    205/55/15 Yokohama s drive
    Sep 2014
    Argyle, Texas
    Since I have the 14" wheel up front.... 185/60R14
    TOYO Extensa
    Rear 225/50ZR15
    TOYO Proxes 888
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Default Kumho
    Quote Originally Posted by Brian Kay View Post
    All,
    Using Kumho ecsta AST 225/50R15 on 3 of our bikes. My son in law has a Toyo proxies 4 205/60R15. Both perform great but 225 looks better in my opinion. Tire direct $89.00 an $10 in a tire shop to install. I removed the wheel and they just mount the tire. I use beads to balance. All is great.
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
    Sep 2014
    Argyle, Texas
    Quote Originally Posted by jtoro1 View Post
    205/55/25 Yokohama s drive
    25" wheel!!!??
    I bet the NANNY hates it, but that it looks COOL!!!!!!
    Vermont
    Default Rear tire replacement suggestion
    I have a 2014RTS-SE6 and I am running the General Altimax RT 43 on the rear.
    Tire size: 215/60 R 15 @ 26 PSI.
    I have 7,588 miles on the General ( I had the original Kenda rear tire changed @ 5,824) the current mileage on my spyder is 13,412. I choose the General tire because of its Performance evaluation, it is listed below.
    Here is the Performance evaluation information:
    Wet:
    Hydroplaning Resistance 8.6
    Traction 8.7
    Dry:
    Cornering Stability 8.7
    Dry Traction 9.0
    Steering Response 8.6
    Comfort:
    Ride Quality 8.6
    Noise 8.3
    Tread wear 8.7
    This is my 2nd season with the General, and the tire still looks new. My spyder handles great, and their are several other spyder owners on this site are running the same tire. ( Pampurrs, Highman2013, cyclekid, garb55,)
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Throw another vote on the Kumho Ecsta AST pile...
    (In the OEM sizing.)
    Coolidge Arizona
    Wet:
    Traction 8.7
    Dry:
    Dry Traction 9.0
    Comfort:
    Ride Quality 8.6
    Noise 8.3
    Tread wear 8.7
    This is my 2nd season with the General, and the tire still looks new. My spyder handles great, and their are several other spyder owners on this site are running the same tire. ( Pampurrs, Highman2013, cyclekid,)
    Deanna
    Add me to the list
    215/60R15 @ 28 puonds
    I had a Kumo on after the OEM tire but did not like the ware on it
    OEM 6,000 miles
    Kumo 12,000 miles
    Altimax 9,000 miles still looks new
    Don
    Vermont
    Quote Originally Posted by garb55 View Post
    Add me to the list
    OEM 6,000 miles
    Kumo 12,000 miles
    Don
    Don,
    I just added you to the list.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    Wet:
    Traction 8.7
    Dry:
    Dry Traction 9.0
    Comfort:
    Ride Quality 8.6
    Noise 8.3
    Tread wear 8.7
    Deanna
    Great tire!
    Pam
    Austin MN
    I also replaced OEM with Kumho Ecsta AST 225-50/R15. Stretched the OEM out to 8700 miles and I now have 17,000 on my Spyder so almost same miles on the Kumho and it isn't showing any wear and the performance has been great!!
    Oct 2011
    Kalamazoo, Mi
    Default Rear tire
    throw in a third for the Kumo. Take the rear shock lower bolt outm finish jacking the bike up. Put on jack stands remove the rear axle need 36mm socket. When axle bolt removed lift the swingarm up and roll the rear tire out. You will also have to take the rear brake caliper off, not forgetting to support / suspend while awaiting reinstallaton. Easy peasy about 3 hours start to finish including getting the new tire mounted. Just a thought for consideration don't worry about balancing the tire take it and ride it for 100 miles. If you think you need to balance it you can always add beads or something. I am confident that you can get a smooth ride without balancing. Enjoy
    Al in kazoo. Just did all 3 while vacationing in California
    2018 F3-T
    2018 F3-T , Pearl White
    Houston
    We sell and install the Yokohama S Drive. Great traction, much better wet weather performance than the Kuhmo and a very well made performance oriented and speed rated tire.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Feb 2015
    NB Canada
    I'll be adding the general altimax.
    No reason. Just I can get it cheap. And really all these tires people are talking about will be better than oem.
    Stiff
    Sent on Note 5 in Taptalk
    2011 RT Limited , White
    Very Active Member bodymanpainter's Avatar
    Dec 2009
    Yulee, Florida
    I'll be changing to the Altamax also just because I like the looks and can get a great price on one.
    I have the Kumo Ecsta on our RT now with 18,000 miles and it's real close to being worn out.
    Toby
    2020 RTL
    Jun 2014
    Schenevus NY
    Add me to the Kumho camp. Netzley's put on one for me in December. It did great on the East Coast Posse trip to Spyderfest. Got about 5000 miles on it so far and it looks almost like new.
    Went for a ride last night after the storms blew through. Hit 15000 miles on the bike. Planning a trip to Virginia next week for work with a co-worker that rides a Sportster. If he doesn't wimp out on me!
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    on your mileage, and have fun on your trip!
    Nov 2012
    North Las Vegas, NV
    Many choices in the 215/60/15 size. I'm running a Michelin Primacy (discontinued) for 19,000 miles so far with plenty of tread left.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Love this community for the great knowledge, great comments and most certainly the great help that everyone gives on a short notice.
    My options are tilting towards the Kuhmo...great looking tire, I can get the OEM size, tread looks cool (nothing to do with anything, lol), and price is about $80-$90 on-line.
    Still going to let the dealer remove, mount, and install the SOB for the $128...some things are worth paying for. Now, if they can't get to it for several days I may think otherwise.
    Thanks again y'all.
    Danbury Connecticut
    Don,
    Deanna
    I have the Kumho on my Spyder. Does that get me on a list ?
    What list is this ?
    There are many women who have included me on their list, but it has nothing to do with tires.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Vermont
    Quote Originally Posted by _..stiffler.. View Post
    Stiff
    Good Choice going with the General Altimax tire. You will like the tire. I am currently running the same tire. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Vermont
    Quote Originally Posted by bodymanpainter View Post
    Toby
    Toby, Excellent choice, I am running the that same tire, on my 2014 RTS-SE6.
    This is my 2nd riding season with the general, and it still looks new, and plenty of tread left. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    Lots of different viewpoints, and lots of different recommendations on tires. Not everyone agrees on which replacement tire is best, but at least we all agree on one thing; that almost anything is better than the OEM brand tire.
    Pam
    Vermont
    What list is this ?
    The Kumho might get you on a list some where .
    The list is on Post # 7.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
