De acceleration Pop?
Occasionally experience a pop when slowing to a stop. On a 2012 RSS-SE5. What is the cause and the cure please. Thank you. John
Do you have an aftermarket muffler? If so, that may be the reason for the popping. I remember when I had my two wheeled motorcycles, it would pop if I didn't install a fuel sensor with the new exhaust.
Depends....
It is normal but with the stock muffler you don't notice it that much. If you have an after market pipe you will notice it much more and depending on the pipe you can add a fuel mixture regulator/controler. I have a yoshimura R77 and poping is there and I can control it with the clutch and throttle but if you have a semi automatic it is tough to do....if it is occasional I would not worry may be a combination of weather and engine temp....
You need new Y pipe exhaust gaskets. Likely only the right side one has gone bad, but you have to change both. That will stop the pop on deceleration.
De accel Pop
Thanks for the help. Stock exhaust. John
Y Gaskets
thank you. I recall reading about Honda gaskets-any idea of a source and Part #s? John
Honda part # 18392-MAM-000
Y Gaskets
Got them ordered. Found a great pictorial- how to replace the Y Gaskets by Wacky Dan. Great site. Appreciate the help. John
+1. Had the same thing happen with mine. Stock exhaust. New Y gasket cured it.
JLohPhotos
I also had the same issue, new gaskets fixed that ?? Not sure why or how , but they did.
I love the decel explosions from my Two Brothers exhaust! I've always been curious why people try to get rid of it. I find it super badass and exotic sounding.
What say you guys that dislike it, reasons why?
Simply because i hate noise.
Will new gaskets and exhaust wrap quiet down the noise from under the tupperware ?
Veni, vidi, discessit
Potius sero quam nunquam
